December 30, 2025, 04:36:27 PM *
Author Topic: May have a problem  (Read 1552 times)
AwesomeDad
TN
« on: October 05, 2020, 07:10:57 AM »
Noticed today while moving the big girl around the garage at full left and right lock the forks contact the radiator....
JJ
WintrSol
Florissant, MO
« Reply #1 on: October 05, 2020, 07:50:42 AM »
If you find and remove #7 on this drawing: https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/frame you will see what happened to the stopper on the steering stem, which is the block below #10, the upper one, on this drawing: https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500ct-a-valkyrie-tourer/steering-stem
Not sure what you can do, short of replacing the stem.
AwesomeDad
TN
« Reply #2 on: October 05, 2020, 07:57:09 AM »
Are you saying I’m missing a part?
« Reply #3 on: October 05, 2020, 08:16:48 AM »
There was another thread just last week on a handlebar stop (at top of tree) that got chipped just enough for contact at full lock on one side.  That's what WintrSol is talking about looking for.
0leman
Klamath Falls, Or
« Reply #4 on: October 05, 2020, 08:48:27 AM »
After reading the above I went to check my I/S to see if it touches the radiator.  I found that I have just about the thickness of a putty knife between radiator and fork.  Is that normal?
« Reply #5 on: October 05, 2020, 09:23:51 AM »
The custom radiator cap covers obviously are going to stick out more than just the OE cap too.
I don't know anything about standard/tourer radiator trim stuff.
RonW
Newport Beach
« Reply #6 on: October 05, 2020, 10:22:57 AM »
I agree, the forks seem to be hitting the trim (x). As 0leman said on his I/S there's only "about the thickness of a putty knife between radiator and fork." The trim doesn't seem flush that added to the trim's thickness.
« Last Edit: October 05, 2020, 10:35:24 AM by RonW » Logged
2000 Valkyrie Tourer
Bagger John - #3785
« Reply #7 on: October 05, 2020, 12:05:07 PM »
Any bike I've ever had that top radiator trim installed on would exhibit same.
Ditto certain brands/sizes of aftermarket radiator cap covers.
« Reply #8 on: October 05, 2020, 04:36:11 PM »
Two things.
One.  It appears your radiator topper may be installed improperly. I would guess the front is positioned over the grill. That puts it a tad farther away from the radiator.
Two. I have that trim. But it doesn’t stick out forward as much as yours. And mine barely misses on the left side and barely touches on the right side but it does touch on the right side.
AwesomeDad
TN
« Reply #9 on: October 05, 2020, 10:28:57 PM »
Two things.
I will try and adjust it or remove it...
JJ
indybobm
Franklin, Indiana VRCC # 5258
« Reply #10 on: October 06, 2020, 05:42:00 AM »
I agree with Chris. The trim should be between the front screen and the radiator. Looks like the trim is in front of the screen.
So many roads, so little time
VRCC # 5258
