August 25, 2025, 03:28:28 PM *
Author Topic: NEW ? corona info  (Read 623 times)
da prez
Wilmot Wi
« on: October 07, 2020, 07:53:02 AM »
  Your father died from a heart attack. We are going to list the cause of death as corona virus.
  Motorcyclist dies in accident. After death corona test(?) is said to be positive.   Cause of death , corona virus. W H Y.
 A friend is in health care administration. She stated that a hospital gets $18000.00 to Handle a corpse.
 If the cause of death is corona virus , they get $38000.00 .
  Another friend is a doctor. We asked him if he had any input , not telling him any dollar amounts. We were given the same numbers.
 Is this why there are so many deaths listed as corona virus? crazy2 crazy2
                                        da prez
« Reply #1 on: October 07, 2020, 09:02:56 AM »
Respectfully, this is a ligitiimate question.  I won't argue that it does happen.
That said  hospitals around the world do not have simar incentives - - especially those in devoping nations where underreporting is said to be a problem.  This is due to unreported deaths in impoverished rural areas where most victims did not see a doctor before checking out.
da prez
Wilmot Wi
« Reply #2 on: October 07, 2020, 11:02:05 AM »
This is local info. If anyone knows healthcare providers  , ask the question.
       da prez
« Reply #3 on: October 07, 2020, 01:35:05 PM »
It sounds like cause for a fraud investigation to me.
« Reply #4 on: October 07, 2020, 06:38:06 PM »
the test they use is fake. it is all a scam. The inventor of the test states it doesn't work how they are using it. I've been posting this since april.
“PCR basically takes a sample of your cells and amplifies any DNA to look for ‘viral sequences’, i.e. bits of non-human DNA that seem to match parts of a known viral genome. The problem is the test is known not to work. It uses ‘amplification’ which means taking a very very tiny amount of DNA and growing it exponentially until it can be analysed. Obviously any minute contaminations in the sample will also be amplified leading to potentially gross errors of discovery. Additionally, it’s only looking for partial viral sequences, not whole genomes, so identifying a single pathogen is next to impossible even if you ignore the other issues.The idea these kits can isolate a specific virus like COVID-19 is nonsense.”
https://www.weblyf.com/2020/05/the-truth-about-pcr-test-kit-from-the-inventor-and-other-experts/
“The urge to save humanity is almost always a false face for the urge to rule it.”
― H.L. Mencken
In the previous entry, we learned how a process invented to increase the size of research samples of DNA called polymerase chain reaction is used to test for viruses even though the guy who received a Nobel Prize for inventing it said using it that way doesn’t work.
Kary Mullis’s PCR process takes segments of DNA through a “cycle” that doubles the amount. If you run a single segment of DNA through just 40 cycles, you’ll end up with 1 x 240, which is over a trillion copies. Remember that number, it’s going to be important later.
We also saw that the COVID-19 virus, like any other virus, is just some genetic code surrounded by a shell that acts as a “Trojan horse,” allowing the virus to invade the cells of living organisms. Once inside, the genetic code exits the shell, hijacking the cell’s functions to make it produce more copies of the virus.
The genetic code inside the COVID-19 virus’s shell is RNA. So, since the PCR cycle only works on DNA, before a sample is tested for COVID-19 another process is used to convert the former into the latter. Once that’s done, the sample is run through a number of PCR cycles to amplify the amount of any converted-viral-RNA that was originally in it so there’s enough be detected.
But two factors are responsible for creating the massive unreliability of PCR testing that, as we saw in part 1, the New York Times reported on but downplayed to push for mass testing of a different kind without discrediting the whole concept.
    The bits of genetic material whose amount is being amplified ARE NOT viruses. They’re just small segments of inert genetic material found inside a virus’s shell. Without the shell, they don’t have any ability to infect a cell and reproduce. The PCR test doesn’t detect “live” viruses, at best it only detects their “remains.”
    The detection of viral remains involves massively amplifying the amount in the original sample by running it through successive PCR cycles. And nothing about the PCR test itself will tell you if there was actually any “live” virus in the original sample.
https://www.redstate.com/michael_thau/2020/09/03/ny-times-up-to-90-of-people-who-tested-positive-for-c19-not-infected-truth-a-whole-lot-worse-pt-3/
