December 30, 2025, 04:36:34 PM *
Author Topic: Growling clutch sound.  (Read 1624 times)
« on: October 10, 2020, 09:50:47 AM »
It's on the trike I recently bought, while idling in neutral I hear a growling sound from inside the motor. It goes away when I pull in the clutch handle. I've also noticed shifting is also rather sloppy but may be due to the system needing a good flushing. Re. the noise, am I possibly looking at a new clutch in the near future?
« Reply #1 on: October 10, 2020, 10:38:34 AM »
John my Bee has made a noise in neutral since the day I test rode it with 0 miles on it. As you say pull i. Lever and it quits.
« Reply #2 on: October 10, 2020, 11:30:29 AM »
It's in the shop getting the leaky differential taken care of. Soon as I get it back I'll start with a flush of the hydraulics, see if that helps the rather choppy function of it. Might need an overhaul of the master and the slave.
CoreyP
Bluffton, SC
« Reply #3 on: October 10, 2020, 09:08:23 PM »
I would think a trike is harder on the drive train so it's probably harder on the clutch. I really know nothing about trikes so ???????? What does that trike weigh? The clutch may run hotter then on a standard bike, that's my line of thought. I've burnt up a couple of clutches along the way but that was from 360's, burnouts etc.  I'm thinking you would need to put higher pressure springs in the clutch on a trike to keep it from slipping as much? Assuming a trike would have more slipping from the drive train.
klb
Hickory nc
« Reply #4 on: October 10, 2020, 11:16:52 PM »
I have a 1999 and 2001 Standard and they both have that noise.
My first one I bought new back in 2001 did it from day one until
I sold it.
« Reply #5 on: October 15, 2020, 06:01:43 AM »
Isn't that just normal great rattle?
Timbo1
Tulsa, Ok.
« Reply #6 on: October 15, 2020, 09:12:23 AM »
I've had very similar sound on my Blue / Cream standard since around 2003 when I got it, goes away when clutch is pulled in just like yours.  But I thought it was just normal.  It wasn't until this September I picked up another Valkyrie (Project) and once I got it running found it doesn't have that same growl or whirring at idle.  It also shifts a little smoother and feels a little more agile, a little more rigid underneath me.   Since it's been so many years with the growl I guess that's not a major concern for me but I will be looking into why old blue is a little more sluggish feeling underneath me.
Jims99
Ormond Beach Fl.
« Reply #7 on: October 16, 2020, 05:24:24 AM »
I have two valks and have riden a few others. Same thing with mine, one is quiter and shifts different then the other. Everyone seems to be a bit different. Both only have around 65k and seem to make the same noises as ones with over 100k. I’m always listening to see if I need to do any work on these old girls, but I know I should just enjoy the ride. Old habits.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
3W-lonerider
Shippensburg Pa
« Reply #8 on: October 16, 2020, 12:19:34 PM »
mine growled from day 1 straight off the showroom floor. after 112,000 miles i had to replace the clutch. it still growled at 214,000 miles.  so i'd say its normal on some bikes.
