March 25, 2026, 08:39:28 AM
Needed: Carbs Replacement or Alt
Topic: Needed: Carbs Replacement or Alt (Read 631 times)
agrady1995
October 13, 2020, 03:48:02 AM »
I made the mistake of having my carbs ultrasonic cleaned AND vapor honed. The butterflies are stuck and wont easily open/close all the way. (vapor honing grit in passages)
Slight remedy by way of adding a partial twist on the "close" spring on two of the carbs, but still idles like crap (1500 RPM) unless I lean forward and give the butterfly a little pull upwards on the left side.
I am not able to remove those pressed in screws on the butterfly in order to pull out the stem and clea the grit out. My ever-growing mechanical ability is not advanced enough to chance it without a backup set of carbs on hand, so it looks like I am in need either way.
Is there any common replacement for the 97' valk carbs, or does anyone have a set of 97' tour carburetors they would be willing to sell?
Andrew, 24, Lakeland FL
Re: Needed: Carbs Replacement or Alt
October 13, 2020, 04:05:00 AM »
Contact Bob aka attic rat or Ross aka daprez.
jdp
October 27, 2020, 09:22:23 PM »
I just did the carbs on 2 Valkyries it wasn’t bad at all the hardest part is putting the air box back on, take your time and get a good carb kit
