December 30, 2025, 04:35:40 PM
carb Orings
Topic: carb Orings (Read 2086 times)
baird4444
carb Orings
October 15, 2020, 01:57:08 PM »
anybody know what size the Orings are that seal the "fuel joint set" tween the rear and middle carb? parts diagram
calls them 16040-MZ1-790 gasket set "B". and do they just butt on the end
of the tube to be compressed or do they actually slip over the tube??
seems I'm a leaking..... - Mike
- ya gotta be SOBER!
-Cody Baird
Re: carb Orings
October 15, 2020, 02:18:23 PM »
I think this is what you are looking for.
https://redeye.ecrater.com/p/6738361/carb-fuel-rail-leak-kit
baird4444
Re: carb Orings
October 15, 2020, 03:28:10 PM »
Quote from: meathead on October 15, 2020, 02:18:23 PM
ZACKLY!! Thank you...
- Mike
-Cody Baird
Timbo1
Tulsa, Ok.
Re: carb Orings
October 15, 2020, 07:51:13 PM »
If your frugal as I am you can save a little by ordering the fuel rail 0-rings from theoringstore.com. The fuel rail o-rings are like .12 each.
http://www.valkyrieforum.com/bbs/index.php/topic,34945.msg1111343.html#msg1111343
Alternatively if you gotta pull the carbs you might want to go ahead and replace all carb & fuel rail seals. I've bought the All balls kit from amazon twice recently and I really like they include so much for around $100 on Amazon.
https://www.amazon.com/All-Balls-Carburetor-Rebuild-Valkyrie/dp/B07DVL9YHG/ref=sr_1_1?dchild=1&keywords=valkyrie+carb+kit&qid=1602816543&sr=8-1
Led
Wisconsin
Re: carb Orings
October 20, 2020, 10:02:06 AM »
Yea......mine have still been "swelling up" yet, when exposed to gas for an hour or so.........
But I know the year is coming, where they won't anymore.........
rug_burn
Brea, CA
Re: carb Orings
October 22, 2020, 06:06:28 PM »
As I ordered these from the O-ring Store:
Material: Nitrile ( Buna-N) 70 Durometer hardness (both)-
N1.30 x 008
N1.78 x 007.94
Can't remember which is for the fuel and which is vapor rail- but buy extra- they're only $0.12 and $.20 each, respectively.
These worked perfect
Last Edit: October 22, 2020, 06:23:33 PM by rug_burn
...insert hip saying here..
=> InZane XXV
