November 12, 2025, 09:43:02 PM *
Author Topic: Dragon Breathe hose.....  (Read 1185 times)
Big Rig
Woolwich NJ
« on: October 23, 2020, 10:46:15 AM »
The residual residue that comes from the airfilter...
What length and id???
« Reply #1 on: October 23, 2020, 06:29:32 PM »
https://www.partzilla.com/product/honda/95003-23008-60M?ref=247d811be93737f3e4219cbc2dd6af036bb6ab9b
This lists the size in metric
sixlow
St. Augustine, Fl.
« Reply #2 on: October 24, 2020, 04:31:36 PM »
8mm ID silicone tubing works fine, it runs from the air box to a "T" {roughly 16 in.} that joins the oil breather behind the ignition switch then runs down underneath {maybe 24 in} with the plug in it.  All these measurements are pure guesses.  Undecided
« Last Edit: October 24, 2020, 04:35:17 PM by sixlow » Logged
Gideon
Indianapolis, IN.
« Reply #3 on: October 29, 2020, 11:54:57 AM »
Here's an easier way to drain the Dragon Drool tube. Go to ACE hardware or a plumbing supply store and purchase a 1/4" X 3/8" nylon barbed fitting with a threaded head. Get a lightweight brass or plastic cap to fit on the threaded head if a cap was not supplied.
Slide the existing clamp up the puke tube and remove the plastic plug and clamp. Place a slightly larger clamp on the tube and insert the barbed end of the nylon fitting into the puke tube. Slide the new clamp over the barbed end of the new fitting.
Trim the barbed end of the nylon fitting if it is longer than the plastic plug. Otherwise it will hang further down than original setup.
Now, when you get ready to drain the tube, just unscrew the cap. No need to bother with moving clamps and pulling plugs!  cooldude
