November 12, 2025, 09:40:55 PM *
Author Topic: Spark plug wire coil end  (Read 1121 times)
SpidyJ
Murrells Inlet
« on: November 09, 2020, 09:04:02 AM »
Just got a new wire  from Honda.  Is that an inductive pickup on the coil end of the wire?
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: November 09, 2020, 09:10:28 AM »
oem cables are copper core wires with a resistor in the plug end of the cable.
an inductive pickup is a term for a certain type of ignition system.
« Reply #2 on: November 09, 2020, 09:34:03 AM »
When you press the wire into the coil, that recess in the coil has a very sharp and pointed needle looking thing that goes into the end of the wire. Once in place, the collar then screws down onto the coil thereby holding it in place similar to a copper tube compression fitting for plumbing. The collar is a two piece item, make sure both are there.
SpidyJ
Murrells Inlet
« Reply #3 on: November 10, 2020, 02:38:00 AM »
Thanks for explaining how that contact works John.  Couldn't tell just by looking at the wire.
Peace,
johnnywebb
