December 30, 2025, 08:44:18 AM
Spark plug change
Pages:
Topic: Spark plug change (Read 4070 times)
Re: Spark plug change
Reply #40 on:
November 16, 2020, 09:38:36 AM »
Quote from: Chrisj CMA on November 16, 2020, 09:25:17 AM
Quote from: meathead on November 15, 2020, 08:28:59 AM
I'm thoroughly convinced after following this thread, when it comes time for new plugs, I'm just putting in. Regardless of what time the clock says it is.
To each his own. You will have no Ill effects. Must of us have done it that way for years. I know it is a little complicated for some.
Don't get your knickers in a wad. it was just an observation about the wild fluctuations on installing/indexing some plugs.
Bagger John - #3785
Reply #41 on:
November 16, 2020, 10:00:39 AM »
Add a little confusion to the process. Go get some iridium plugs with multiple ground electrodes, screw 'em in and start an oil thread about it...
Reply #42 on:
November 16, 2020, 10:55:43 AM »
Quote from: Bagger John - #3785 on November 16, 2020, 10:00:39 AM
yrunvs
Prior Lake, Minnesota
Reply #43 on:
November 16, 2020, 02:45:03 PM »
Would that be 9 o'clock AM or 9 o'clock PM???
Last Edit: November 16, 2020, 02:47:35 PM by yrunvs
I'm no gynecologist but hey I'll take a look!
Reply #44 on:
November 16, 2020, 03:01:41 PM »
Quote from: yrunvs on November 16, 2020, 02:45:03 PM
Yes!
Reply #45 on:
November 16, 2020, 03:02:07 PM »
Depends on what side of the equator you are on.
da prez
Wilmot Wi
Reply #46 on:
November 18, 2020, 07:10:37 AM »
WHO'S ON FIRST.
da prez
Reply #47 on:
November 18, 2020, 07:37:58 AM »
Quote from: da prez on November 18, 2020, 07:10:37 AM
WHO'S ON FIRST.
da prez
All I can tell you is how easy the bike starts and how smooth it idles. If any of it is due to indexing spark plugs it’s well worth the time and if not well nothing really lost anyway.
Reply #48 on:
November 18, 2020, 03:53:25 PM »
I always cut back the side electrode so half of the center electrode is exposed and then round the end.
I also use a plug with a reduced size center electrode, presently TRW champion powersport #8812
https://www.ebay.com/itm/CHAMPION-POWER-SPORT-POWERSPORT-Spark-Plugs-8812-1-8812-RA8HC-RA8GHC-Set-of-8-/133014095848
spark plug mod
https://musclecardiy.com/wp-content/uploads/2016/05/317.jpg
https://www.musclecardiy.com/performance/automotive-horsepower-secrets-ignition-systems/
yrunvs
Reply #49 on:
November 18, 2020, 04:52:35 PM »
As I see it... all this talk about spark plug mods and such is all fine and dandy but if you really want to increase power then losing about 15 lbs of belly fat = about +- 2.2 HP.
Last Edit: November 18, 2020, 04:55:48 PM by yrunvs
Pages:
=> InZane XXV
