December 30, 2025, 08:44:20 AM *
Author Topic: Anyone have a wiring diagram for I/S fog lights?  (Read 1116 times)
« on: December 10, 2020, 08:48:40 PM »
The trike I recently bought is a converted '99 I/S and has the fog lights in the radiator pods. When I first gave it a test ride prior to buying it, I noticed the lights were on all the time and the switch had no control. I was told the switch had failed so instead of replacing it, he just cobbled together some wiring so they run all the time. Having just pulled the pods off I found some odd colored wires clipped together along with those worthless Scotch lock clips so as it is now, I have no idea how it's supposed to be wired. If you have a wiring diagram for the fog lights on the I/S I'd appreciate a copy of instructions. I can probably figure it out but would involve tracing the harness back to the source and figuring out how it's all hooked up using a switch.
« Reply #1 on: December 10, 2020, 09:55:56 PM »
Scroll down, 2d from bottom.  http://www.valkyrienorway.com/download.html
http://www.valkyrieforum.com/bbs/index.php?topic=81592.0
https://web.archive.org/web/20180220200613/http://www.rattlebars.com/mtz/foglites.html
