December 30, 2025, 06:54:40 AM *
Author Topic: windscreen whisle  (Read 1286 times)
mbramley
Painesville Ohio
« on: December 17, 2020, 07:33:37 AM »
 I put a new Memphis Shades  windscreen this summer. It whistles. It's coming from the bottom right corner, I can put a couple of fingers on the bottom edge and it stops. I tried filing a little on it thinking smoothing it out a bit might help. It didn't. Before I destroy my new windscreen I figured I'd better ask if anyone else has had this and how they solved it. I'm guessing that may be why I got a deal on it.
da prez
Wilmot Wi
« Reply #1 on: December 17, 2020, 12:07:38 PM »
Be sure all fasteners are properly tightened. If need be , put a small piece of gasket material in that corner by the screw mount.
         da prez
« Reply #2 on: December 17, 2020, 12:27:59 PM »
Take the screen off Evil
« Reply #3 on: December 17, 2020, 05:43:18 PM »
Won't look great, but a custom cut piece of hard foam rubber jammed in there will quiet it down.
boss hoss bill
« Reply #4 on: December 19, 2020, 06:24:47 PM »
I had this same problem years ago. I took some clear scotch tape and wrapped it around the perimeter of the right turn signal and believe it or not, it stopped the whistling on my 2003 Walk with a stock Hondaline windshield.
Hope it works for you!
mbramley
Painesville Ohio
« Reply #5 on: December 21, 2020, 03:57:52 AM »
  Thanks for the replies, they started salting around my parts so she is put up for the winter now. I will try these come spring. I really hoped I would have a couple more rides this year. That is except taking it off. I've tried that a couple of times over the years and I don't care for it. I guess I'm a wimp.
