December 30, 2025, 06:54:13 AM *
Author Topic: Shop air compressor Electrical issue  (Read 1374 times)
da prez
Wilmot Wi
« on: January 07, 2021, 10:00:49 AM »
  I have a 3HP piston compressor. Bought it in December of 17. The other day , it would not go to speed. It would blow the circuit breaker.  I removed the belt and the motor  would start and run. I tested the start capacitor . It checked good along with the run capacitor. Reinstalled and put the belts on. Same thing. I purchased a new start capacitor. Same thing. I did not replace the run capacitor as it also checked good. I hooked to a different power supply. same issue.
 WHAT AM I MISSING. crazy2
                                               da prez
Factor
Clayton, NC
« Reply #1 on: January 07, 2021, 10:12:18 AM »
With a replaced start capacitor that still doesn't get it rolling, I'd look at either the electric motor having too much resistance (bad bearing? rotate by hand to check) or the actual piston/crank having too much resistance (rotate by hand, check oil, pull head off and look at cylinder walls). I guess it could also be some poor electrical connections that are limiting the amps from the start capacitor getting to the windings of the motor. Also check your motor bushing and clean up the contact surface.
Steve
VRCC# 38798
'75 Hoda GL1000 Project
'83 GL1100 MonkeyWing
'70 Suzuki T500 Titan
'99 Valkyrie Tourer
'64 MGB
'89 Isuzu Trooper 3.4L
IBA #58082
All my stuff is old. It makes me feel young.
WintrSol
Florissant, MO
« Reply #2 on: January 07, 2021, 11:12:48 AM »
You say you disconnected the compressor from the motor by removing the belts, right? That means it is all in the motor. An electric motor will draw as much current as it can to overcome resistance to its designed run speed, blowing the breaker, which means it is unlikely the brushes (if it has them). That leaves something binding between the rotor and stator. Something could have been sucked in with the cooling air and jammed between them, or a bearing may be failing; if it uses solid bearings, one could be worn out of round, letting the rotor touch the stator. It is possible the brushes (if) are shorting, and cause the same effect - easy to check on inspection.
OK, I re-read your post, and it said the motor seemed to run fine when the belt was removed. So, back to the compressor ...
« Last Edit: January 07, 2021, 02:16:21 PM by WintrSol » Logged
Challenger
« Reply #3 on: January 07, 2021, 01:50:28 PM »
Have you checked to make sure the compressor unloader valve is functioning? I had the exact symptoms and had to replace mine.  Too much torq needed to start with pressure on heads.
JimC
SE Wisconsin
« Reply #4 on: January 07, 2021, 02:08:39 PM »
Prez,
I am guessing that you checked this already.
I had one do the same thing, ended up being clogged air intake. I had just finished painting a car and it filled the filters solid with paint.
Jim
Jim Callaghan    SE Wisconsin
da prez
Wilmot Wi
« Reply #5 on: January 07, 2021, 04:46:04 PM »
I checked the unloaders,  air filter and the compressor pump
 I misstated initially
 The motor would not go to speed on its own. After two attempts,  it started working
 This is not my first time with electric motors. I am still wondering what I missed. If this compressor has 50 hours on it , I would be amazed.
                 da prez
WintrSol
Florissant, MO
« Reply #6 on: January 07, 2021, 06:17:53 PM »
                 da prez
OK, back to something that got jammed between the rotor and stator, or a rotor making intermittent contact with the stator. Can you open it up? I know many motors that size can't be opened, and then still be able to be put back together.
Steel cowboy
Spring Hill, Fl.
« Reply #7 on: January 08, 2021, 04:03:27 AM »
Try this, you stated you used another power source. I’m assuming you meant another outlet, but is the new outlet on the same circuit as the first? You could have a weak circuit breaker. If it’s a GFCI circuit that could be a problem too.
2001 black interstate
2003 Jupiter Orange wing
WintrSol
Florissant, MO
« Reply #8 on: January 08, 2021, 12:23:59 PM »
Also, since this changed recently, it could be the wire terminal at the breaker has loosened, which creates heat, which not only reduces power to the motor, but will pop the breaker.
da prez
Wilmot Wi
« Reply #9 on: January 08, 2021, 12:30:42 PM »
Different outlet , different circuit. I'll have time tomorrow.  Thanks for the help.
                 da prez
