March 14, 2026, 01:21:27 AM *
Author Topic: Toyo CT  (Read 1653 times)
boppa
Rome, Ga
« on: December 28, 2009, 12:36:27 PM »
Well it's almost time for a new rear tire and I'm going to go to the darkside. My question is which Toyo would you suggest as I work at the Toyo plant hear in Ga. Any help with size and modle tire will be appreciated. Thanks in advance. Cool
« Reply #1 on: December 28, 2009, 12:47:34 PM »
the toyo proxes T1R is what I had on, also misfit and therapist had it before me
I dont run it now but that is no reflection on the tire but on my ability to be comfortable    As an urban assault tire it was fine  I couldnt handle it in the twisties to my satisfaction
art
Grants Pass,Or
Grants Pass,Or
« Reply #2 on: December 28, 2009, 02:47:07 PM »
I have this tire but went to a 195 55 an I get less bump stear.It handles better on bad roads
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #3 on: December 28, 2009, 03:46:11 PM »
i dont have a toyo, but i will tell you that reading the literature from those that went to a CT, really helped me know what to expect. i will say that you will feel everything at low speeds, you will have to man-handle it into the corners. you will see it want to straighten itelf out of a corner on accel. but once you get used to it, you'll love it.
VRCC#31391
VRCCDS0239
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: December 28, 2009, 10:44:31 PM »
I run the Toyo Proxes TPT in 205/65HR16.  I love it.  I wanted a 65 series to bring the rpms down.  I only had to cut the nut cages.  Before I hooked the shocks back up and put Sandman back on the ground, I pushed the ct and swingarm as far up in the fender as I could to check for interference.  There wasn't any.
Marty
Mr.BubblesVRCCDS0008
« Reply #5 on: December 29, 2009, 01:28:32 PM »
I'm running the toyo proxes T1R  205/60/16  and have about 15k on it and it still looks good.
