December 30, 2025, 06:54:12 AM
anybody know if this comes out?
Topic: anybody know if this comes out? (Read 1589 times)
shadowmagic
January 10, 2021, 08:27:06 AM »
So I ordered another handle for the throttle because I broke a small piece off the yellow part that holds the throttle cables around it. Anyway, the handle is in worse shape than mine and I was hoping there is a way to take out the yellow insert and replace the actual grip with the one on my bike currently. Any help would be greatly appreciated. I was goona try and force it but it seems like it will break.
SCain
Rio Rancho, NM
Re: anybody know if this comes out?
January 10, 2021, 09:09:17 AM »
On the stock grip and throttle tube you should be able to unscrew the chrome cap on the end use a small thin screwdriver pry it under the grip spray some WD-40 in there and work it around.
Steve
shadowmagic
January 10, 2021, 11:01:12 AM »
awesome, thank you for the tip. Illl try it today.
WintrSol
Florissant, MO
January 10, 2021, 11:34:05 AM »
You may want to use a worn screwdriver - a new one with sharp corners can tear at the parts.
January 10, 2021, 12:27:14 PM »
Load it up with regular rubbing alcohol, that usually will help soften or dissolve the sticky stuff. Slip a small screwdriver under the outer part and either pour or squirt the alky in. Do it in a number of places.
January 10, 2021, 01:25:32 PM »
The best tool for grip removal is an ice-pick. Carefully wiggle it a bit, then use a spray solvent, with thin nozzle sistered up next to the pick, and squirt. Repeat until it slides off.
Honda grips I cut off because I don't care for them.
But whatever you do, be careful with the throttle sleeve underneath the throttle grip.
Some use an air compressor but I never did.
Reply #6 on:
January 12, 2021, 02:18:20 PM »
I would use none of the above suggestions. How I removed mine was put a small nozzle on the air compressor hose and shot air between grip and body. Took about 15 seconds and it was off. When you shoot the air under the grip the grip will separate from the glue and swell a bit and it just slips off easily while still shooting the air under.
BTW take the chrome end off and go at it from that end.
vanagon40
Greenwood, IN
Reply #7 on:
January 12, 2021, 06:11:00 PM »
Quote from: Jess from VA on January 10, 2021, 01:25:32 PM
. . . Some use an air compressor . . . .
Quote from: Bighead on January 12, 2021, 02:18:20 PM
. . . put a small nozzle on the air compressor hose and shot air between grip and body. . . .
=> InZane XXV
