November 12, 2025, 05:47:58 PM *
Author Topic: Problem with Choke  (Read 1789 times)
Jaskin71
Mornington, Ireland
« on: January 16, 2021, 05:23:35 AM »
Hello all, hope you are well.
Just quick one. Since I got me IS the choke wasn't working properly.
It goes half way loose when Im trying to open and after then Im feeling the pressure of the choke and it not stay in that position. It slowly goes back and close the choke.
I have opened the housing on handlebar and there is everything ok. Then I took down the side covers and found out that the choke line is soo long. But the adjustment is on its max.
Is it the time to change the line or is there any other way to adjust it a bit?
(have some pics but forgot how to put them here )  angel
Any advice?  Thanks Jiri
« Last Edit: January 16, 2021, 05:25:20 AM by Jaskin71 » Logged
« Reply #1 on: January 16, 2021, 06:03:38 AM »
One of my Interstates, the choke won't stay fully on and eases off while the bike is still cold.
I have to stand there for two minutes and hold it on for warm up.
I think something got oiled that shouldn't have.  I have not tried a fix.
« Reply #2 on: January 16, 2021, 07:36:12 AM »
I oiled my choke cable years ago. It still won't stay on.
I wonder if there's such a thing as "canned rust" I
could spray down in there?
« Reply #3 on: January 16, 2021, 11:08:45 AM »
I would order and install a new cable. Cheap and easy.
« Reply #4 on: January 16, 2021, 11:31:44 AM »
there are cable adjustment nuts on each carb bank, chrome covers need to be removed.
handle bar adjustment should be done last and as fine tuning.   see pg 5-18 of tech manual
similar procedure for throttle cables. handlebar is final adjustment.
« Reply #5 on: January 16, 2021, 11:58:05 AM »
I don’t know of an adjustment possible at the handlebar. I do have a standard so maybe different on the interstates but I doubt it
Jaskin71
Mornington, Ireland
« Reply #6 on: January 16, 2021, 12:20:46 PM »
Hi. Yes there is adjustment on the handle bar side as well.
I did both sides on max and the cable is still a bit long.
Will try to replace it.
« Reply #7 on: January 16, 2021, 12:33:54 PM »
I just did John Schmidt's choke mod, thereby removing the handlebar cable.
 Works great and I like how it cleaned up the look by removing that cable.
semo97
Texas
« Reply #8 on: January 17, 2021, 05:41:43 PM »
Where is John's choke mod write up
« Reply #9 on: January 17, 2021, 05:44:12 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,93903.0.html
semo97
Texas
« Reply #10 on: January 17, 2021, 06:05:57 PM »
Thank You Sir
Led
Wisconsin
« Reply #11 on: January 18, 2021, 10:55:35 AM »
I know......just splitting hairs here......
But "chokes" went out in the late 60's......early......1970's???     NOW they are "enricheners".
Instead of "choking" off the air flow......they started "enrichening" the fuel flow.......at cold start up.
But whatever works......even I still call it a CHOKE!!!!  Lol!!!  cooldude
I STILL, prefer the old choke carbs.......a LOT less to go wrong!
« Last Edit: January 18, 2021, 11:14:40 AM by Led » Logged
« Reply #12 on: January 18, 2021, 12:11:12 PM »
I've known that a long time, but still always call it a choke (as you basically get the same result with either).
I'm not a fan of the word enrichen.
Also choke is only one syllable, and enrichen is three and takes longer to say.     Grin
