December 30, 2025, 04:56:04 AM
Wheel Dampers
Topic: Wheel Dampers (Read 1180 times)
msb
Agassiz, BC Canada
Wheel Dampers
January 18, 2021, 12:10:55 PM »
Just curious to know...what is "typical" for movement with rear wheel dampers in place? I replaced mine 3 years ago even though the ones I had in there showed no real signs of wear...just because. Just doing the rear end service again this past week, and was wondering if the 1-2 mm "play" in the new ones is normal....again, no visible wear. I do recall these last ones dropped in very easily when new. They are the OEM dampers.
Thx.
'99 Red & Black IS
Re: Wheel Dampers
January 18, 2021, 12:53:01 PM »
The play in individual dampeners is not the problem. If there was not a lot of black rubber dust in there they’re probably good. The real test is how sloppy is the flange unit once installed If it’s not real wobbly then you’re good.
bikerboy1951
Grand Forks, ND
Re: Wheel Dampers
January 18, 2021, 01:51:10 PM »
You can't polish that beast if you are doing maintenance. I thought I saw a little dust on the gas tank last time you posted a pic.
Brad
msb
Agassiz, BC Canada
Re: Wheel Dampers
January 18, 2021, 02:00:44 PM »
Quote from: Chrisj CMA on January 18, 2021, 12:53:01 PM
thx, I'm sure I'm good to go
'99 Red & Black IS
Re: Wheel Dampers
January 18, 2021, 03:37:01 PM »
Not just the dampers, but considering the entire drive train from Ujoint to pinion cup to pumpkin to wheel there's always some flex in there (has to be).
The (heavy) Valk can be very torquey departing from stop to go, especially if you goose the throttle before clutch let off. I always try to hook up easy off a rollout from stop,
before
I ever nail the throttle (if I'm launching hard for any reason, or just fun).
I've had those good (non crumbling) Shockbushing Gary polyurethane dampers in my bikes for years now, and they tighten things up, but there's still flex in there.
=> InZane XXV
