January 30, 2026, 05:03:14 AM *
Author Topic: Audio, clock switch box  (Read 2340 times)
Doc X
« on: December 30, 2009, 07:47:37 AM »
When I push in on my clock button nothing happens , beep and flashing time display, so I can't reset my clock on my interstate. Help please!
thanks,
Doc X
Grumpy
Tampa, Fl
« Reply #1 on: December 30, 2009, 09:27:37 AM »
When it is flashing, volume and channel selectors change the time.
Doc X
« Reply #2 on: December 30, 2009, 09:44:44 AM »
It want flash when I  depress the clock switch and hold it in, it will not flash no matter how long it is depressed.
Doc X
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #3 on: December 30, 2009, 01:47:16 PM »
actually it should be a press and release. i am sure you tried that.
VRCC#31391
VRCCDS0239
Joe Hummer
Arnold, MO
« Reply #4 on: December 30, 2009, 02:00:30 PM »
your switch is probably a little dirty.  Try pressing it in several times then hold it in to set the time.  Mine does that too at times...contacts get a little dirty and they don';t make contact.
Joe
1999 Valkyrie Interstate
Doc X
« Reply #5 on: December 30, 2009, 02:04:09 PM »
Joe, I tried that, No go.
Doc X
Joe Hummer
Arnold, MO
« Reply #6 on: December 30, 2009, 02:10:28 PM »
Well...sounds like you are going to have to crask that bad boy open and clean the contacts.
MaverickValk
« Reply #7 on: December 30, 2009, 07:22:53 PM »
Radio has to be on to set the clock, meaning either the AM/FM, AUX or the CB. Try that.
Maverick
