November 12, 2025, 03:56:21 PM *
Author Topic: Anyone have or know where I can find a Center Cover ?  (Read 1733 times)
In Between
« on: January 25, 2021, 07:26:17 PM »
Just noticed the Center Cover tab that holds the left side cover on has the tab broken.  Found a few used ones, but way out of my ball park.  Smiley
Thank you
Ken
« Reply #1 on: January 25, 2021, 07:30:47 PM »
https://www.ebay.com/itm/164471051284
« Reply #2 on: January 25, 2021, 07:35:30 PM »
I may have a black one.  What ball park are we talking here?
In Between
« Reply #3 on: January 25, 2021, 07:47:51 PM »
Awfully rough
Thank you
Ken
In Between
« Reply #4 on: January 25, 2021, 07:49:11 PM »
A small town ball park, not Wrigley Field.
Thank you
Ken
« Reply #5 on: January 25, 2021, 08:58:46 PM »
      Get some a b s plastic and some a b s Black hardening glue and fab up what you need. The A B S hardening glue when it sets up can be filed sanded and painted. I repaired a cracked saddle bag with this process. da prez-My Brother B T W-has done some of this very repair I'm talking about. Take your time and figure what you need to do. And what ever you do let the glue Cure as long as it's sposed to. RIDE SAFE.
In Between
« Reply #6 on: January 26, 2021, 03:03:51 PM »
Appreciate the comment.  looks like eitherr this or velcro.  Would like to find the original part but 100 is too much for me.
Thank you
Ken
« Reply #7 on: January 26, 2021, 03:24:05 PM »
Mine's not broken, so I don't have direct experience, but hidden
velcro seems like a fix I'd try...
« Reply #8 on: January 26, 2021, 06:47:20 PM »
I will bet with a few minutes of polishing you would feel different.
But hey if $100 is too steep good luck.
In Between
« Reply #9 on: January 26, 2021, 06:49:31 PM »
Thank you
Ken
« Reply #10 on: January 26, 2021, 08:21:56 PM »
Mine was screwed, to a metal bracket that bent around to the side cover.
My side cover tab was broken off. I placed a bent washer in a bed of ABS glue, then topped it off with some JB Weld 5 min epoxy.
Works fine. As long as you remember how to remove the covers, it shouldn't bend/brake. A lot less expensive than buying a new one, and it's not seen anyways, as the fix is on the inside.
In Between
« Reply #11 on: January 27, 2021, 03:15:39 PM »
Appreciate it
Thank you
Ken
psckam
Elmira, New York
« Reply #12 on: February 01, 2021, 05:00:34 AM »
I recall someone using Neodymium magnets glued in strategically. Can't remember where I saw it,  but it was a invisible and strong cure.
« Reply #13 on: February 01, 2021, 05:21:37 AM »
That sounds like a great idea!
In Between
« Reply #14 on: February 01, 2021, 01:58:01 PM »
Great idea too
Thank you
Ken
« Reply #15 on: February 08, 2021, 05:54:37 PM »
if someone wants to bring some to inzane I will pay
both of my tabs are broken and I am using tape  they broke while replacing alternator
that magnet idea sounds awesome
