December 30, 2025, 01:14:05 AM *
Author Topic: Vacuum lines and such  (Read 1888 times)
GL15Brewer
Wherever I may roam
« on: February 02, 2021, 01:10:12 PM »
So I am finally putting the valk back together after a carb rebuild. I am finding I did not take enough pictures before. My clymer book says the emissions label is under the left panel but it isnt. I am wondering if anyone knows which intake vacuum lines go to what. I've got open nipples on intake 3, 4, and 6. I'm under the impression 2 of the 3 are connected and then go to the PCv. I believe the 3rd connects to the same tube that connects to the rear of the take and dumps under the bike. Also I have the 2 hoses off the carb assembly I'm not remembering where they connect. Thanks for the help as always.
Cheers
GL15Brewer
Wherever I may roam
« Reply #1 on: February 02, 2021, 01:25:23 PM »
I have a picture but cannot figure out how to add it.
« Last Edit: February 02, 2021, 01:33:01 PM by GL15Brewer » Logged
« Reply #2 on: February 02, 2021, 01:46:20 PM »
#3 & #4 have a vacuum line that meets at a “T” then go the PAIR valves. #6 goes to the petcock
GL15Brewer
Wherever I may roam
« Reply #3 on: February 02, 2021, 01:52:32 PM »
Chrisj CMA thanks much, that helps a ton. Any ideas on the 2 air hoses coming off the carburetor assembly? they are the ones that T off underneath the fuel lines.
« Reply #4 on: February 02, 2021, 01:53:54 PM »
If they are the ones kinda captured on the frame of the carbs. They don’t go anywhere. Just vents
GL15Brewer
Wherever I may roam
« Reply #5 on: February 02, 2021, 01:54:53 PM »
each one comes from a T connection off the carb assembly.
GL15Brewer
Wherever I may roam
« Reply #6 on: February 02, 2021, 01:59:29 PM »
« Reply #7 on: February 02, 2021, 03:14:07 PM »
I tried to look. I think the vents come off a T. Are these lines significantly fatter than the ones that went to #3 and #4. If so they terminate in s hole in the carb bank frame
GL15Brewer
Wherever I may roam
« Reply #8 on: February 02, 2021, 07:32:00 PM »
Yes they are. I got the rest put back together and fired up. Sounded amazing. So much better with the carbs clean. Gonna put some new plugs in it and think I've got I'd done as far as carb and hoses goes. Thanks so much to everyone for the help. If the general consensus is those 2 tubes off the carb assembly just stay open then I'm ready for a ride.
RonW
Newport Beach
« Reply #9 on: February 03, 2021, 12:47:36 PM »
« Last Edit: March 01, 2021, 06:38:32 PM by RonW » Logged
2000 Valkyrie Tourer
GL15Brewer
Wherever I may roam
« Reply #10 on: February 09, 2021, 08:54:06 PM »
RonW that's exactically what I needed. Thanks much.
RustyValkry
New Jersey
« Reply #11 on: March 01, 2021, 05:45:25 PM »
I'm about to start replumbing my carbs so this questions is relevant to me.  Please confirm that the first picture above is mislabeled.  The stay with the enricher cable attached it the Rear stay, not the front.  If that's the front stay then my carburetor world just turned backwards.
Thanks.
RonW
Newport Beach
« Reply #12 on: March 01, 2021, 06:07:33 PM »
Probably! If you go by the direction the fuel line from the T-joint points.
RonW
Newport Beach
« Reply #13 on: March 01, 2021, 06:19:47 PM »
