August 13, 2025, 03:25:58 PM
question about ignition switch wiring
Topic: question about ignition switch wiring (Read 1077 times)
shadowmagic
February 07, 2021, 01:41:49 PM »
So the plug and play switch I bought seems to be a little different. Any advice on how I should go about this. I took a couple of pictures to show the difference. As always, any help greatly appreciated. The red one is the new one.
Last Edit: February 07, 2021, 01:44:16 PM by shadowmagic
Re: question about ignition switch wiring
February 07, 2021, 01:57:06 PM »
Match each wire to its mate with the wiring diagram and then move the brass thinggys. You can use an ice pick to release the brass spring tooth thing and then it pulls right out
Last Edit: February 07, 2021, 02:00:12 PM by Chrisj CMA
Jims99
Ormond Beach Fl.
February 08, 2021, 05:03:52 AM »
Standard/ tourer models are different than interstates. Did you get the right one? Interstate has acc. When turned backwards. Could account for different wires.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
=> InZane XXV
