December 30, 2025, 01:14:07 AM *
Author Topic: Has anyone replaced the saddlebag and radiator cover reflectors with lights?  (Read 1763 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« on: February 20, 2021, 10:49:46 AM »
If so any links to suitable in size shape to the Valk one can purchase?
Any pics?
Gondul
VRCC #408
Central Florida
« Reply #1 on: February 20, 2021, 11:25:21 AM »
Cheapest I've found so far is $40 for a set... which seems stupid expensive for LEDs
I'd just fine some side marker lights and roll with something I like...
No pics... can't stand hosting sites.
https://store.valueaccessories.net/AmberLEDMarkerLights.aspx
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
« Reply #2 on: February 20, 2021, 12:33:55 PM »
Jerry, some time back I stopped at the 75 Chrome shop on SR44 & I-75 where I picked up a couple LED lights almost the same size as the saddlebag reflectors. I left the reflectors on and drilled small holes through them for the mounting bolts...quite small. A third hole for the wiring which I ran around the top of the bag just under that top lip. One lead I used the top forward bag mount bolt for ground, the other I used a bullet connector just outside the bag which drilled a small hole in at the top. Actually were quite bright. I'll see if I can find a picture(s). At one point I had two small relays activated by the turn signal which made these LEDs flash alternately with the rear turn signals. Over the years it drew a few comments but the install was rather simple, and you need either two relays...one for each side, or a dual action single relay. Depending on the directional trigger, that would determine which side of the dual is making contact.
Pics added. You can see the LED lamp is nearly the same size as the reflector which I left in place.
Showing the ground connection. With a small wire it keeps the hot lead real small thereby making the exit hole tiny. A little RTV keeps it dry inside.
I made the hot lead long enough to allow tipping the bag outward for disconnecting prior to removal.
« Last Edit: February 20, 2021, 01:06:25 PM by John Schmidt » Logged
« Reply #3 on: February 20, 2021, 01:03:39 PM »
 (If you do this) I seem to remember reading that if you grounded the saddlebag reflector-led upgrade to the turn signal circuit, they would flash with the signal activated.  (so run-turn)
I don't have them on my bikes.
« Last Edit: February 20, 2021, 01:05:46 PM by Jess from VA » Logged
_Sheffjs_
Sarasota FL
« Reply #4 on: February 20, 2021, 03:05:33 PM »
Thanks. Information sent to Norway Valkster
GARY G
tampa fla
« Reply #5 on: February 20, 2021, 04:12:43 PM »
Any pics?
      yes Jerry  Bill did  you dont rember   dont know ware he got
                    them
PAPA G
flash2002
Montreal, Que
« Reply #6 on: February 20, 2021, 06:10:24 PM »
I got these lights for my bike. They replace the original lights on the bags and I got yellow for the rad. They way I run them is parking and flasher.
      https://www.ebay.com/itm/1x-LED-Reflector-Rear-Tail-Brake-Stop-Marker-Light-Red-For-Car-Truck-Motorcycle/124341121839?hash=item1cf34ef32f:g:h98AAOSwYKZfYGh2
« Reply #7 on: February 20, 2021, 06:50:09 PM »
This works but the LED has to be grounded to the positive side of the turn signal. The turn sig light has to be a conventional incandescent bulb. That way the LED is grounded through the filament of the turn signal bulb.
« Reply #8 on: February 20, 2021, 07:46:57 PM »
I made my own for the back.
At the time there were some available that were just a little longer than the space on the saddlebag. Maybe they’re still available?
« Reply #9 on: February 20, 2021, 07:49:26 PM »
FWIW....all my turns, front and rear, were LEDs. I just normally grounded the lights I installed on the bags as shown in the second picture. That mounting bolt screws into the bag mounting frame.
Jims99
Ormond Beach Fl.
« Reply #10 on: February 21, 2021, 06:44:07 AM »
I did my tourer bags with ones from JP cycle. I had to sand the bottom corner of chrome just a bit for it to fit in the insert. They’re also hooked for run turn and brake. Did the ambers on the interstate front also. Fit perfect and also have them as running and turn.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Diesel
Los Alamitos, CA
« Reply #11 on: February 23, 2021, 11:53:55 AM »
I have the add-on accessories LED reflectors on my IS bags and and front fender.  Red on bags and amber on front fender.  Perfect size.  pn 45-1227R / Red and 45-1227A / Amber
« Reply #12 on: February 23, 2021, 01:21:26 PM »
I installed these lights so I would have an extra brake lights. first I made a stain less steel plate that fit where the reflector was and then installed these lights. I also used LED brake/running bulbs.
 these have been discontinued, but there are other similar styles out there.
https://fortnine.ca/en/drag-specialties-capsule-marker-lights-ds280173?__cf_chl_jschl_tk__=121cabbdf504a5e33a4be2a1f43db3774be3d839-1614114680-0-AYgpBnyjj7fyhqwsHHnAwYDMrKgOz_rdPmSbHN7q1Xs5JCZ1biZZwRS5qg50ZYIeKu66xO4y477p6O6HwKvLEFyjJVzfpFJZDh5gIInjA2cMecbsflN-VSPyWtXzA0MUkfCZOW8tE3XoXewgoOcPNi-p_jBdLz348qA4qFeL8aU4XZZFTxaQeNBuinJQZ75kw4ZhQ25g477sp9FBJT8orUN63s3DXQ1pDPJq7bHRi6qyvJKpz_hQSh-Wo2yCyCY1zuNAV4fY-JzStpkB-T1Wvvra_UAvT4e8lxMm6iu8ozs66s8G8wTJRFCd6G_kXri5ldCorZfNVn4N7EFX61DvcPY2UY5rKUW0PTbZcsnmSS3UpbRkFEY1HIT4WNNEEHU1OTF7W5vXDqtdPJCvPIheaE0z6XP8OTGgvPIwxtBAem-_Rs8cXPgPCebDg90x7d3i1A
Ramie
2001 I/S St. Michael MN
« Reply #13 on: February 27, 2021, 02:47:59 PM »
Big Bike has the amber.
http://www.bigbikeparts.com/templates/product.aspx?ProductGuid=16-107A&GroupGuid=16&catalogNo=1
Gondul
VRCC #408
Central Florida
« Reply #14 on: February 28, 2021, 06:00:25 AM »
$60 for LEDs?   2funny 2funny 2funny
Yeah.. they can fleece someone else.
John Adams - 1797
