March 24, 2026, 10:42:38 AM *
Author Topic: Revolution Max 1250 is Harley-Davidson’s most powerful engine 150 hp, 94 lb-ft  (Read 678 times)
« on: February 22, 2021, 07:06:54 PM »
https://advrider.com/harley-davidson-revolution-max-1250-engine-the-mocos-future/
The Revolution Max 1250 engine (a 60-degree V-twin) takes things much further. Along with liquid cooling, the engine also has a computer-controlled variable valve timing system (VVT) on both the intake and exhaust camshafts. Other manufacturers (BMW, Ducati) have variable valve timing, but only on the most expensive, advanced bikes, so Harley-Davidson is exploring new territory here.
According to H-D’s presser, the VVT system “advances or retards exhaust and intake camshaft timing independently through a potential range of 40 degrees of crankshaft rotation.” You know how motojournos always say an engine is “tuned for torque” or “tuned for horsepower”? Well, this allows Harley-Davidson to tune for both. The presser says “VVT broadens the overall powerband and improves torque management and efficiency compared to the same engine with fixed valve timing. This allows the same engine to provide both low-end grunt for acceleration off the line as well as the thrill of high-RPM horsepower.” Harley-Davidson also says it can improve fuel mileage.
The engine itself uses single-piece aluminum cylinders, forged aluminum pistons, and magnesium rocker covers, cam covers and primary cover. Not exactly mind-blowing technology, but you need to make these steps to improve performance or reduce weight, or both. The heads are aluminum as well; because the heads are a key mounting section of the chassis, Harley-Davidson used targeted heat treating to make them flexible at the mounting point, but rigid over the combustion chamber.
« Reply #1 on: February 22, 2021, 07:22:17 PM »
Can't blame them for trying (in fact, I'm glad they are trying) but, it's still a V Twin and it's still a HD.  Not interested, I want to be able to reliably get to where I started out for.  Just my opinion.  But, my opinion dictates where I spend my dollars.
Jack B
Two Rivers Wis
« Reply #2 on: February 23, 2021, 04:29:59 AM »
I notice the engine looks different depending on what side of the bike you look at, plus the price is a bit high
No thanks
Let’s RIDE
« Reply #3 on: February 23, 2021, 04:52:40 AM »
Rich kids have to have somewhere to spend their money.
« Reply #4 on: February 23, 2021, 06:50:36 AM »
               yawn. yet another over priced V-twinky. Phatt Ghurl 22 year old And STILL moves me. RIDE SAFE.
