March 24, 2026, 05:26:06 AM *
Author Topic: JIS screw drivers  (Read 3992 times)
« on: March 04, 2021, 10:05:04 AM »
      Well I ordered a set from Amazon. Prior to That I called wally wurld. They do NOT reveal their menu until you hear a c19 spiel and other platitudes bout how much my business is preciated! o k I guess!
       Then I decided to call H/F and the one I chose-Rolla Mo-got a gal I had an impossible time convincing her jis is NOT a brand but a style.  Lips Sealed Lets just say I no longer wanna follow That avenue.  uglystupid2
       The jis from wally wurld available on line only and will take longer than Amazon. You'd think that either store would have Someone Qualified to actually discuss tools! Both times I heard the key board in the backround. But I digress Again!  Undecided Maybe I am gittin too old and set in my ways!  Roll Eyes
       And B T W-my Amazon order will be here Saturday the 6th of March.
      Here's a scary thought-these young uns be picking our nursing homes!!  2funny
       Could you imagine tryin to splain points and a rotor to these younglings? Yeah-me neither. RIDE SAFE.
« Reply #1 on: March 04, 2021, 10:10:14 AM »
That's how it starts.....
You try local first, give up, then order on Amazon.
Over time, sadly, you give up on local places and just go straight to Amazon.
They have it, their price will be decent, and they can get it to you scary fast.
Ruthless, but brilliant business model.
« Reply #2 on: March 04, 2021, 10:33:27 AM »
               I Always make it a point to give my local Honda dlr first shot a larger ticket items. The dlr done me right on battery once. They price matched Amazon. I went there before I ordered my A G M battery. No go that time.  Lips Sealed Win some lose some. RIDE SAFE.
Sorcerer
Brooklyn Center MN.
« Reply #3 on: March 04, 2021, 10:37:17 AM »
Try Shinhopples.
« Reply #4 on: March 04, 2021, 10:44:13 AM »
It’s not just young people. I’m sure there are plenty right here who do not realize there are different “Phillips”. Personally, I wish EVERYBODY would switch over to a world wide Torx (or similar) style.
« Reply #5 on: March 04, 2021, 11:06:00 AM »
Awww....pair of pliers, screwdriver, roll of duct tape(& maybe a condom)! If you can't fix it...that's what the condom is for.  Roll Eyes
Just remember; wrinkles in your duct tape is a sign of poor workmanship! Wink
Gideon
Indianapolis, IN.
« Reply #6 on: March 04, 2021, 11:19:34 AM »
[/quote]
signart
Crossville, Tennessee
« Reply #7 on: March 04, 2021, 12:10:55 PM »
You can get Vessel JIS screwdrivers on evil bay. There is no better.
« Reply #8 on: March 04, 2021, 03:03:53 PM »
with the new standard all are the same except for one as noted in link.
I have harbor freight screw drivers made to the new std they work great on my cycles.
https://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/
There are the real JIS and the not-so-real JIS screwdrivers. Remember, JIS is a standard, so a screwdriver needs to be made to that exact standard to be considered authentically JIS.
Most JIS advertised screwdrivers sold today by companies like Vessel, Hozan, and others are actually conforming to a new standard: DIN 5260 which is identical (at the tip) to the newer ISO 8764-1.
But wait, DIN stands for Deutsches Institut für Normung e.V. (German Institute for Standardization), and ISO is the International Organization for Standardization. Neither sound very Japanese, do they?
The reason these companies have changed to DIN 5260/ISO 8764-1 is because the new standard is designed to work in both Phillips and JIS screws. For the most part that is true, it does work on both screw types, but like anything meant to work with multiple things, the middle ground means compromise. The JIS standard screwdriver will always outperform a DIN/ISO screw driver in the worst of conditions on a JIS screw, and the same is true in reverse.
As you can see, the JIS and ISO standards are very close, but not exactly the same:
If you only need one set of screw drivers, or are an infrequent user, the new DIN/ISO standard screw drivers will likely work for you, but if using the right tool for the job is important to you or if you frequently work with Japanese or JIS screws, consider investing in proper JIS screw drivers that are built to JIS B 4633.
To date, I have only been able to find one confirmed manufacturer that still uses and builds to JIS B 4633, and that is SUNFLAG otherwise known as New Turtle in Japan:
« Last Edit: March 04, 2021, 03:10:07 PM by 98valk » Logged
« Reply #9 on: March 04, 2021, 03:47:08 PM »
Just get a cheap screw driver with a tray of different bits.
One or more of them will be right.
« Reply #10 on: March 04, 2021, 03:56:56 PM »
+1 They can be easily fine tuned with a belt sander or grinder also.
« Reply #11 on: March 04, 2021, 04:29:11 PM »
That's how ya' round off the front brake and clutch master cylinder screws.... JIS is a very different animal, most of the big trays of bits don't have JIS bits.
...and our Valkyries really need JIS screwdrivers...
« Reply #12 on: March 04, 2021, 07:07:47 PM »
Do you have one of those cheap screw drivers with a little tray of 14 different "phillips" looking
bits? They're not all #2 phillips. You'll find that one of the bits that is PERFECT. I know someone
who has used one for 15 years and his master cylinder reservoir screws are still good  Roll Eyes ...
« Reply #13 on: March 04, 2021, 07:11:47 PM »
I've got a few.... and a few stripped out master cylinders I replaced when they were hopelessly stripped, until I got a dedicated, not too expensive JIS set of screwdrivers....
Seriously.... Putting a JIS screwdriver into one of the screws of a Valk is pure sex.... It's just "ahhhhhhhh" THAT'S how it's supposed to be!
« Reply #14 on: March 04, 2021, 07:16:24 PM »
That's what I'm talking about.
-Mike "next to the the cash register at the Auto Parts store..."
« Last Edit: March 04, 2021, 08:06:43 PM by hubcapsc » Logged
« Reply #15 on: March 04, 2021, 07:30:32 PM »
If it's the master cylinders one is concerned about, they should have hex screws anyway.  They look better in that application and they're easier to remove and replace.   Smiley
« Reply #16 on: March 05, 2021, 04:28:20 AM »
yep, one of the first things I changed.
« Reply #17 on: March 05, 2021, 04:38:35 AM »
Every Honda I've ever owned had one in the toolkit.
Some even have the "T" handle.
« Reply #18 on: March 05, 2021, 05:03:15 AM »
Absolutely  cooldude ...
Here's my lefty-loosy-righty-tighty (see the little switch?)
screwdriver that I've had since the dawn of time. I never
used it, and would never use it, except that when I got my
Valkyrie I found that it had a perfect bit (JIS I'm sure) in its
tray for all my little "phillips" Valkyrie screws. You can see
(sorry for the fuzzy picture) that all the bits in the tray
are kind of rusty and unused looking, but the one in the
handle is well used.
When you get a cheapo screwdriver with a tray of whacky bits,
one-or-some of them is going to be JIS. Especially (but probably
anyhow) if your cheapo screwdriver is old enough to have come
from Japan.
-Mike "my Valkyrie screwdriver"
h13man
Indiana NW Central Flatlands
« Reply #19 on: March 05, 2021, 06:56:53 AM »
Having Snap On SAE ergo set for 25 yrs., I bought a pair Vessel brand JIS phillips. I use these on all phillips head be it SAE or JIS. Magnetic tips to boot. Just grip better IMO.
https://images-na.ssl-images-amazon.com/images/I/61kG4UniRzL._AC_SL1500_.jpg
« Last Edit: March 06, 2021, 05:04:47 AM by h13man » Logged
signart
« Reply #20 on: March 05, 2021, 08:16:57 AM »
...and better handle than Snap-on. Not to mention the knurling just below the handle is what makes this the best "phillips" screw driver ever on JIS or SAE.
« Reply #21 on: March 05, 2021, 12:20:00 PM »
I also have Vessel.  cooldude
I put it in a drawer other than the one with the 87 non-JIS screwdrivers.
So I can't find it.
Though I'm a little better organized than this.
« Last Edit: March 05, 2021, 12:23:03 PM by Jess from VA » Logged
« Reply #22 on: March 05, 2021, 01:38:31 PM »
this is the one I have. check out the tip, its exactly as the Vessel tip Jess posted.
https://www.harborfreight.com/2-x-4-inch-phillips-screwdriver-94707.html
Bret SD
San Diego, Ca.
« Reply #23 on: March 05, 2021, 04:23:59 PM »
I have a set of these and they're really good..
https://www.summitracing.com/parts/wmr-w1710?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+P&utm_term=4581939832700478&utm_content=GSAPI+5ba28fd9454f1
Bret
02 Standard -- Blue & White
82 Aspencade -- Red
« Reply #24 on: March 06, 2021, 04:54:03 AM »
Many of the bit sets in Home Depot come with this. They are cheap, available, can use a ratchet and extension and work well.
h13man
« Reply #25 on: March 06, 2021, 05:13:58 AM »
Here's a writeup for comparing the JIS and Phillips differences.
https://bike.bikegremlin.com/10583/phillips-vs-jis-vs-pozidriv/
« Reply #26 on: March 06, 2021, 07:06:21 AM »
most important statement right there and goes along with my post/link Thanks
"In chapter 3.2. I explained how JIS was discontinued as a standard in 2008, so now there is only ISO 8764. In other words: almost no manufacturers today make and sell screwdrivers noted as “JIS”, only “Phillips, ISO 8764-1, 2”. Some might (also) mention “DIN 5260-PH”, but no “JIS”."
« Reply #27 on: March 06, 2021, 12:06:15 PM »
C'mon guys, we're guys. Its another chance to buy more tools.
« Reply #28 on: March 06, 2021, 12:09:38 PM »
            And I no longer have a spousal unit that I need ta splain "stuff" to! RIDE SAFE.
« Reply #29 on: March 06, 2021, 05:02:05 PM »
Y'all just talked me into buying one.
Normally, I wouldn't spend $10 on a single screwdriver but you guys made it sound like I needed one.  Evil
signart
« Reply #30 on: March 07, 2021, 05:59:55 AM »
I can't over emphasize the advantage of the aggressive knurling below the handle of the Vessel. It's like an overdrive between finger & thumb when inserting or removing screws.
« Reply #31 on: March 07, 2021, 04:47:46 PM »
   O K the set I purchased from Amazon came from A B Tools set#LSR58. All 4 are JIS and the lenghts are 150MM long with a PH3 100MM long with a PH2 75MM long with a PH1 and a 38MM with a PH2. Used em today and the Are Magnetized nicely. Just missed $36.00 but they seem right from the git go to work better on the screws on Phatt Ghurl. That's My story and I are stickin to it!  Roll Eyes RIDE SAFE.
