January 28, 2026, 05:11:10 AM *
Author Topic: starter button blowing fuse when pushed  (Read 6511 times)
roadmap
« on: March 07, 2009, 05:13:55 PM »
my starter button blows my running light fuse when i push the button.. the lights stay lite ok they don't blow a fuse just under normal conditions. just when i push the button. the light goes dim like it supposed to do the whole switch housing is new just a few months old and the starter sylenoid has been replaced new also that was a long time ago like last year. i check it no signs of it bad.
the only thing i did out of the way different i washed the bike with the seat off  that was yesterday it blew fuses yesterday as soon as i put them in. today fuse stays good till i hit the starter button it got me drinking allot go figure.. fuse are about a .80 now apiece at auto zone..went through 10 fuses already not sure, need help
also brake light works ok and headlight, all other acc. don't blow. front turning signal, brake running light and dash lights.are whats goes out  1997 140,000 miles
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: March 07, 2009, 05:20:45 PM »
Sounds like you've got water in the electrical system.  I would start by removing the fuses and relays and drying them out.
roadmap
« Reply #2 on: March 08, 2009, 08:38:32 AM »
need advice how about by passing the starter button so the running lights do not go dim when you push the button it only blows fuse when i hit the button i went over everything. starter relay good no burnt marks new.. starter button.. new bought it new a couple of months ago been working fine i just took it apart check it, ok,  just put some new electric lube on the connection .. i put dual relay on headlight to protect my new switch they been on since the switch was new. headlight works ok if relay was bad it would blow my headlight not my running lights. how about my ICM could this be shorting out. what other relay, not the turning signal lights they work ok and do not blow as well as my brakelight. fan everything checks. not sure if washing the bike did it i don' t drive much at night it could of been out a while.
man i blew a fan on it last night then a hair dryer for a while no water on anything
still what got me is the fuse don't blow,, everything works great so how do i check for a short when it doesn't show bad, no fuses blow under normal condition,  just when i hit the button it blows  this i know is hard to answer wonder if mark T or somebody that does electrical work reads this
roadmap
« Reply #3 on: March 08, 2009, 10:38:01 AM »
one last thing to write about the new starter switch works ok because it dims the headlight when starting.  i keep going over things nothing ads up
John U.
Southern Delaware
« Reply #4 on: March 08, 2009, 06:08:34 PM »
The starter switch is supposed to cut power to the lights while connecting power to the starter relay. If it is only dimming the lights it isn't working properly. The lights would dimm anyway due to the draw of the starter.
« Reply #5 on: March 08, 2009, 06:26:40 PM »
Yeah, I concur. You got a short that needs finding. Good analysis will help out lots.  Review the last things you have done to help see if that could be the cause of your problem. Don't jump to conclusions that can exacerbate your problem.
roadmap
« Reply #6 on: March 09, 2009, 03:04:38 AM »
i will agree something not  right. but i have not done anything. just noticed it after i washed the bike. i guess something got wet.. i washed the bike without the seat on.  what i am trying to figure out, it only blows when the current is interrupted (push the button). turning the key off & on, that is not it. operating the turning signals, that is not it. brake light, that is not it. they have there own fuse, but it interrupts or ads power to the current,  ok!!  starter button new late last year, this works the headlight fine, with that in mind the the switch is still good.
now what to check, the wires that run from the switch to the fuse panel no way to check all the wiring. at the ends or where connections are. now it is getting harder . the fuse operates under normal condition just fine. so how do i check something that is working right at the time of checking. that tells me no breaks in the wiring. no bare wires.
PLEASE TELL ME WHERE TO GO FROM HERE.   WHERE IS THE SHORT WHEN THE FUSE WORKS OK
time to check starter switch
junior
new hampshire
« Reply #7 on: March 09, 2009, 03:12:54 AM »
you could have pinched the wires in the switch housing when you reassembled it
« Reply #8 on: March 09, 2009, 07:25:33 AM »
You need to put those driving lightx on a relay, it tells how in the shop talk section.
« Reply #9 on: March 09, 2009, 08:34:31 AM »
There you go!
#7 reply is right on.
