Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: January 02, 2010, 03:40:30 PM » |
How often do you all change out your clutch/brake fluids? I do my coolant and rear end annually, although I have only changed out my clutch and brake fluid once, Guess that's something I've been overlooking
Bone
« Reply #1 on: January 02, 2010, 03:56:15 PM » |
I do them every 2 years.
Bone
« Reply #2 on: January 02, 2010, 04:02:30 PM » |
Just looked at the manual. It recommends every 12k miles. Stop and go driving would make a big difference.
alph
« Reply #3 on: January 02, 2010, 04:22:21 PM » |
once it starts to look a little dark. every couple years.
Promote world peace, ban all religion. Ride Safe, Ride Often!!
Pete
« Reply #4 on: January 02, 2010, 05:30:49 PM » |
+1 I am with Alph.
« Reply #5 on: January 02, 2010, 05:49:16 PM » |
Every March regaurdless. It only takes a little time and is not expensive. Plus it gets me to stay in the garage more!
alph
« Reply #6 on: January 02, 2010, 07:23:32 PM » |
Every March regaurdless. It only takes a little time and is not expensive. Plus it gets me to stay in the garage more!  another married cyclist!!
« Reply #7 on: January 02, 2010, 07:38:45 PM » |
Every March regaurdless. It only takes a little time and is not expensive. Plus it gets me to stay in the garage more!  another married cyclist!!  Why do ya think I got divorced the 1st time!
MP
North Dakota
« Reply #8 on: January 02, 2010, 08:01:10 PM » |
Check the color. Those who live in high humidity areas need to change more often. It is moisture that gets in that causes the problems.
MP
 "Ridin' with Cycho"
Spirited-6
« Reply #9 on: January 03, 2010, 04:24:03 AM » |
Looks like Ginger Ale; good to go. Looks like iced Iea; not good to go.
Spirited-6
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #10 on: January 03, 2010, 05:13:07 AM » |
Iced tea-Ginger Ale...I can related to that
Ferris Leets
« Reply #11 on: January 05, 2010, 11:31:02 AM » |
Iced tea-Ginger Ale...I can related to that  I got my '99 IS in July, the first thing I did was change ALL fluids. The brake and clutch fluid was weak coffee, I doubt it had ever been touched. My Nomad went 9 years on the same fluid and it looked as good coming out as the new stuff going in.
shortleg
« Reply #12 on: January 06, 2010, 04:04:41 AM » |
Goody and I helped BigBF a few years ago at Inzane and we were vrey suprized at the number of Valks that were in need of a change. Here in Maryland I have found that it last about 2 years , But I do mine every year when I change all fluids. Do it with the antifrezze
Kilroy
« Reply #13 on: January 06, 2010, 06:22:35 AM » |
Tundra, I do it every year, I have speedbleeders on both the brake and clutch lines so it goes quickly. The fluid is cheap so why not? Kilroy
"I was here, but now I'm gone"
Spirited-6
« Reply #14 on: January 06, 2010, 06:43:02 AM » |
Speedbleeders; those are not cheap.  Here is what I do/ have done. Get a jar / bottle, I used a Volka bottle, wonder where that came from  . Clear hose that fits on bleeders, drill a hole in bottle top, hot glue hose in top, make sure hose goes to bottom of bottle. I used about 2 1/2 feet of hose. Fill bottle with about 1" of fuild and attach end of hose to bleeder. Pump and fill, old fuild fills bottle as you pump and fill. You can see when fuild runs clear in hose and your done. Took me about 30 minutes to do whole system. I put a small clamp on the bottle so it would stand alone on floor. This has worked great for me and will use again, I saved bottle.
Spirited-6
Farther
« Reply #15 on: January 06, 2010, 07:17:51 AM » |
Speedbleeders; those are not cheap. Speed Bleeders cost less than the purchase price of your vodka bottle.
Thanks, ~Farther
Spirited-6
« Reply #16 on: January 07, 2010, 06:21:29 AM » |
Speedbleeders; those are not cheap. Speed Bleeders cost less than the purchase price of your vodka bottle.  ???
Spirited-6
