November 12, 2025, 01:39:53 PM *
Author Topic: Isolating Popping Sound  (Read 1429 times)
agrady1995
« on: March 19, 2021, 05:23:21 AM »
Did a carb rebuild for a guy, and having some issues.
Had the carbs apart twice now, with the same issue. Heres the setup:
New Red eye (all carb o rings plus bowl gaskets)
No leaky air cut valves, all vacuum tested
No holes (even pinhole, im 25 I can see fine) in the slide diaphragm
New intake boots and air box tubes
new intake runner-head o-rings.
Desmog kit installed, all fasteners triple checked tight.
#2 and 4 on the left side are popping lightly at idle and pretty bad at higher RPM, load or not. I suspect the brand new intake boots (carb runner-carb) but progressively tightened them more and more and pretty much bottomed out on the tightness without snapping the little clamps.
Had a similar problem on my interstate, fixed with the addition of a SS hose clamp. Was hoping not to do that to him, so I'm asking if there is any other possible reason for the popping...
Briefly ran with #2 and #4 ignition wires swapped (5 min and a half mile)
Cleaned the problem carbs twice now, but when I pull the runner and plugs they have as much fuel on them as the other (working) plugs and runners.
Pulling plug boots resulted in no popping as there was no fire, for those two cyls.
Plugs are brand new, but not since the accidental plug wire swap, if that could be a problem.
Thanks in advance.
Kilroy
« Reply #1 on: March 19, 2021, 06:44:28 AM »
Do you know if it popped any before?
Header gaskets could cause it...
Ramie
2001 I/S St. Michael MN
« Reply #2 on: March 19, 2021, 09:06:23 AM »
Have you verified the air cleaner assb is on correctly, sometimes the back side of the boot can curl back.
Jersey
VRCC #37540
Southern Maryland
« Reply #3 on: March 19, 2021, 12:57:59 PM »
You have quite a number of things going on.  May I suggest you reach out to Dave Wilder.  He's probably one of the best (if not the best) around with carbs.
You didn't mention the exhaust copper gaskets.  If they are not sealing properly it'll pop.
Jersey
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #4 on: March 19, 2021, 02:50:01 PM »
Check your vacuum lines for cracks
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
