January 30, 2026, 06:31:51 AM *
Author Topic: glasspack mod  (Read 2875 times)
wiplash123
« on: January 02, 2010, 03:52:15 PM »
 I would like to thank everone for the help on my last post!!!!!!!!! I found the purple honies but they dont make one with a 2" inlit and outlet
if it is over 2" would I have to rejet the carbs. The purple honies are made by flowtech they make another glasspack called the red hots has anyone tried them. I also found a new cherry bomb that is 12" overall. does any one have a recondition thanks for the help
dreamaker
Harrison Township, Michigan
« Reply #1 on: January 03, 2010, 04:43:06 AM »
I don't know what difference the 2" inlet would make because it gets cut off anyway. I guess what method of mod you are going to use. I did my own mod and used the Que-Express' Glass Pack Mod, which I liked the sewage nipple as a collector to promote even flow. Also if I wanted to change my muffler I just had to screw a new on. Far as cherry bombs I had them on my Chevelle and I raddled my neighbors dishes, they were outrageously loud, I switched to turbo mufflers. I don't know if it would be the same on a bike. I figured that length would be a factor, that is why I went 18" instead of 12". I guess far as the outlet if you need to you could go from 2 1/2" to a 2" reducer. I think I made a good choice, because when we start our bikes the HD's are louder then my Valk. It don't get loud till you crank the throttle. I want be loud enough that people to know I am there at a light, but not to annoy them. I hope this helps.
Dan
Mr.BubblesVRCCDS0008
« Reply #2 on: January 08, 2010, 08:17:29 PM »
My hornies were 2in and I didn't rejett anything. I used the header mufflers and cut the flange off and welded the mufflers right to the cut off end of the cans.
hvacjack
Paradise, Texas
« Reply #3 on: January 10, 2010, 10:46:36 AM »
I am going to do my glasspack mod soon I found Magnaflow (10444 or 14444) have 2"in and out. and I always liked Magnaflow performance and sound I will post pics and sound demos when done but it will be a while. I say that but when I get started I will likely work long hours till it's done, I wish I could put something down and take a break once started.  Embarrassed
