November 12, 2025, 01:41:07 PM *
Author Topic: Vacuum hose  (Read 1077 times)
Twofeather
Benton, Arkansas
« on: March 20, 2021, 05:31:48 AM »
Does anyone know which carb has the vacuum hose from the petcock with out the desmog?
FROM MY DEAD COLD HANDS
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #1 on: March 20, 2021, 05:48:57 AM »
#6  (left side, rear)
 Smiley
Twofeather
Benton, Arkansas
« Reply #2 on: March 20, 2021, 07:14:48 AM »
That  is where I have it. Just wanted to make sure. Thanks
da prez
Wilmot Wi
« Reply #3 on: March 20, 2021, 08:49:12 AM »
  Right rear is easier to install.  Any one will work tho.
                                                  da prez
RonW
Newport Beach
« Reply #4 on: March 20, 2021, 09:04:26 PM »
                                                  da prez
Agreed, 5 is easier than 6 to instal. 5 being on the right-side of the bike nearer the backside of the petcock.
The reason why 5 is used is that some people disconnect the vacuum hose at its lower end (5 or 6) instead of disconnecting the vacuum hose from the petcock at the upper end, per manual. But, without desmogging there's a lot of clutter to snake the vacuum hose down on install. If you haven't desmogged it's probably better to disconnect the vacuum hose at the petcock at the upper end. Plus the length of the vacuum hose was designed for 6.
2000 Valkyrie Tourer
