August 19, 2025, 03:28:31 AM
Coolant temp light
Topic: Coolant temp light (Read 1664 times)
rafalc
Central NJ
Coolant temp light
March 22, 2021, 11:06:09 AM »
Could someone help me out and take a look at your Tach indicator lights please. After turning the key to ON position but before turning on the motor, I know the OIL PRESSURE light is lit, is that the same for the COOLANT TEMP light or does this one stay OFF?
Re: Coolant temp light
March 22, 2021, 11:24:04 AM »
Going from memory. The Interstate coolant light initially comes on. The Standards (and Tourers) don’t.
rafalc
Central NJ
March 22, 2021, 12:47:19 PM »
Quote from: meathead on March 22, 2021, 11:24:04 AM
Thank you, it stays OFF on my Standard when key is in the ON position. Just wanted to confirm I didn't fudge any wiring....
Ken aka Oil Burner
Mendon, MA
March 22, 2021, 02:38:00 PM »
I just confirmed on my 98 STD. Key on; no temp light.
www.kgsynthetics.com
March 22, 2021, 05:51:59 PM »
what yr? did u read your owners manual? there was an electrical change and sensor change after '99.
I don't know if that affected the light.
see pg 19-11 of tech manual
Last Edit: March 22, 2021, 06:05:07 PM by 98valk
Dr K
Southern michigan
March 26, 2021, 03:14:40 PM »
My 98 standard has a temperature light module that is supposed to turn the temp light on with the key then it is supposed to go off this checks the light however the light is always on . Does anyone know a re-wire for this ? the module is very scarce
Jims99
Ormond Beach Fl.
Reply #6 on:
March 29, 2021, 04:55:00 AM »
Here’s what I have.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
=> InZane XXV
