August 19, 2025, 03:27:56 AM
Oil
Topic: Oil (Read 1128 times)
~ Ron ~
It's the right thing to do
Ahwatukee, Arizona
Oil
March 23, 2021, 03:35:14 PM »
If you put 3.9 Qts of oil in, how much is left in the 4th Qt?......23 ozs or 16ozs?
~ Ron Pierce ~
~Ahwatukee, Arizona~
~VRCC 20050~
~TOI 27850 ~
~2000 Valkyrie / DFT ~
WintrSol
Florissant, MO
Re: Oil
March 23, 2021, 03:49:45 PM »
Quote from: ~ Degotoga ~ on March 23, 2021, 03:35:14 PM
Seriously? If this is a real question, then you have 0.1 quarts, or 3.2oz; less than 1/2 cup.
rug_burn
Brea, CA
Re: Oil
March 23, 2021, 04:07:27 PM »
And it's also okay to overfill the oil a little bit... It'll just be that much longer until it's low.
...insert hip saying here..
Re: Oil
March 23, 2021, 04:54:23 PM »
Just pour in the 4 qts. I just don’t hold them upside down and drain every drop pour and go. Dont worry about it
Re: Oil
March 23, 2021, 08:23:36 PM »
If you run the bike hot before draining, and if when draining (filter already off, and pull both the fill plug
and
the dipstick off) you get on and lean it over to the right and hold it for a minute or two after it's just dripping (make sure the pan is still catching when leaned), then it will take the whole gallon and be centered up perfectly on the dip stick. (I always put down a garbage bag under the pan.)
It does for both of my interstates, every time.
Of course, you have to run it some after the change to refill the filter, then let the oil settle again.... before checking. And checking is done with the dipstick in, but not screwed in.
(If you are still a mm or three high on the dip, it's no big deal.)
The service manual is very well done, but just every once in a while, I find something in there that seems to be aimed at idiot-proofing maintenece work. I think
3.9 quarts
is one of them.
Last Edit: March 23, 2021, 08:42:01 PM by Jess from VA
h13man
Indiana NW Central Flatlands
Re: Oil
March 24, 2021, 06:43:53 AM »
I'll put this out here, you can use the "longer" filter such as a #3323 Bosch and not worry about using all 4 qts.
~ Ron ~
Ahwatukee, Arizona
Re: Oil
Reply #6 on:
March 24, 2021, 08:42:02 AM »
Thanks for the response.......LOL
, there are people awake out there...
~ Ron Pierce ~
~VRCC 20050~
~TOI 27850 ~
=> InZane XXV
