December 30, 2025, 03:09:12 AM *
Author Topic: Battery replacement  (Read 2042 times)
Roadog
« on: March 24, 2021, 12:03:33 PM »
 I need to replace the battery in my '98 Tourer .  What is a good and reliable battery you have had good service from . Please advise and thanks .
  Roadog,
  Ride Safe
~ Ron ~
It's the right thing to do
Ahwatukee, Arizona
« Reply #1 on: March 24, 2021, 12:44:03 PM »
I'm running a Battery Tender Lithium battery. and it's great so far. you would have to get a Battery Tender charger that would work on both lead-acid & lithium and set it to lithium on the switch to charge. The Battery has a reset button on the end plug and is screwed into the battery to reset if needed. There is no weight on the battery compared to the lead-acid......its really great.....
~ Ron Pierce ~
~Ahwatukee, Arizona~
~VRCC 20050~
~TOI  27850 ~
~2000 Valkyrie / DFT ~
« Reply #2 on: March 24, 2021, 01:18:49 PM »
u don't need a special lithium charger. the charger one is using just must not have a Sulfation battery mode which puts charging voltage past 14 volts. not all everyday chargers have a sulfation mode.
https://advrider.com/f/threads/motorcycle-batteries-agm-gel-wet-lithium-iron-phosphate-lifepo4.757934/page-149#post-42006935
Ramie
2001 I/S St. Michael MN
« Reply #3 on: March 24, 2021, 06:16:59 PM »
Yusa AGM are some of the better one's I've had.  Cheaper than lithium.
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #4 on: March 24, 2021, 06:27:28 PM »
YUASA lead acid batteries seem to be the Cadillac of motorcycle batteries.  I did have one go bad (shorted cell) at around 24 months.  In desperation and on a weekend, I replaced that YUASA with a Duracell from Batteries Plus.  That battery is going strong at 36 months.  So, yeah...a Duracell.  Huh?
I'll probably go with a lithium battery once the Duracell gives out.
Also, I have a YUASA battery in my wife's Shadow that's coming up on 60 months.  It's going strong and shows no sign of giving out.
 Smiley
« Reply #5 on: March 24, 2021, 07:50:27 PM »
On battery tenders (when not riding) my Yuasa's last for 5-7 years, or more.
BUT, my bikes are not kept in an attached garage.
Though my shed has not burned down in 30 years.
« Reply #6 on: March 25, 2021, 05:39:25 AM »
my Bike Master LifePo4 battery gives better mpg and acceleration due to it being 6 lbs lighter than the AGM it replaced. that's six pounds of dead weight removed and along with the PAIR valves complete removal which is another 3 lbs, it was a great diet of 9 lbs.
 I used a larger size LifePo4 than standard due to riding down to 30F temps. Using a correct size battery would have been 1-2 lbs lighter.
h13man
Indiana NW Central Flatlands
« Reply #7 on: March 25, 2021, 06:06:36 AM »
Yuasa or Napa are the only brands I've used. Never had a battery failure but did replace a 13 yr. old Napa out of preventive care. Haven't tried Duracell though two of our four wheelers use them. I'm big fan Sam's Club for tires etc. thus the Duradell purchases.
F6Dave
« Reply #8 on: March 25, 2021, 08:32:32 AM »
I just bought an OEM Yuasa (YTX-14BS) from Rocky Mountain ATV/MC.  Only $70 and it arrived in 2 days.  They have free shipping over $75, so I added a $10 tool.
Tfrank59
'98 Tourer
Western Washington
« Reply #9 on: March 25, 2021, 11:09:08 AM »
Yuasa and you won’t be sorry
-Tom
Roadog
« Reply #10 on: March 25, 2021, 03:15:27 PM »
    I took the advise and picked up a Yuasa YTX-14-BS  today and installed it and all is well once again.   Thank you all for your responses , many thanks .
Roadog
Ride Safe
« Reply #11 on: March 25, 2021, 07:40:19 PM »
      Little late to this party But I have a Yuasa A G M I'm Happy with!  cooldude RIDE SAFE.
