December 30, 2025, 04:56:07 AM *
Author Topic: Upper Radiator hose at the Thermostat  (Read 2016 times)
prezzr1
Monument, CO
« on: April 07, 2021, 09:43:57 AM »
Good Morning All,
I'm about to remove the radiator to tighten the upper radiator hose.  I've tightened the others but couldn't get to upper at the thermostat.  Before I remove the radiator, is there a short cut or trick to getting to the thermostat?  I had a small deposit of coolant on the floor after this winter.
Bill
1999 Valkyrie Interstate
9,944 miles
Monument CO
Doc
1972 Kawasaki H2
1979 Honda CBX
1999 Honda Valkyrie Interstate
2007 BMW K1200R Sport
2021 BMW R18 First Edition
« Reply #1 on: April 07, 2021, 09:47:53 AM »
Look in from the left side of the engine, just above the engine guard. If the hose clamp is positioned right, you can reach in with a long ratchet extension and an 8mm socket.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: April 07, 2021, 12:20:06 PM »
I think mine is a 6mm. I had to buy a new socket just for that.
« Reply #3 on: April 07, 2021, 04:19:51 PM »
I have posted previously on this.  If you do remove the radiator, remove the skinny OEM Honda hose clamp and replace it with a regular sized automotive clamp.  They are about twice as wide and provide  for sealing/clamping area.  If you open the clamps all the way you don't have to drain the coolant to replace it.
I used to have leaks there every winter, non since I replaced the clamp.
luftkoph
E U.P. Mich
« Reply #4 on: April 07, 2021, 05:27:22 PM »
Cold leaks, I’ve fixed mine with constant tension clamps
Some day never comes
WintrSol
Florissant, MO
« Reply #5 on: April 07, 2021, 05:51:55 PM »
Do you use the ones for 'firm hose' or 'soft hose'?
luftkoph
E U.P. Mich
« Reply #6 on: April 08, 2021, 07:30:11 AM »
I did not know there was a difference, I get them from bell metric, there made in Germany that’s all I know about them, and that they work. The only ones I didn’t replace where the two that connect the inlet pipes to the Y hose from the water pump, just not enough room for the tool unless you remove the exhaust, and I wasn’t that motivated at the time, maybe next time I have the exhaust off I will.
« Reply #7 on: April 08, 2021, 09:44:21 AM »
That's strange because a couple years ago I replaced all the hoses, including that bottom "Y" and never removed anything but the hoses. No need to touch the exhaust, and I used better clamps while at it.
luftkoph
E U.P. Mich
« Reply #8 on: April 08, 2021, 02:24:37 PM »
With the constant tension you pretty much need a tool for them and even one with a cable there just isn't enough room, regular worm drive clamps plenty of room for a screwdriver
