December 30, 2025, 04:56:56 AM *
Author Topic: drive shaft stuck  (Read 1480 times)
firemaned52
« on: April 08, 2021, 08:51:59 AM »
Servicing the differential on 1997 valk but unable to remove the drive shaft from the pinion cup.  What am I doing  wrong?
Ramie
2001 I/S St. Michael MN
« Reply #1 on: April 08, 2021, 09:14:50 AM »
There's a circlip on the end of the drive shaft in the pinion cup but it should pull out with a little force.
firemaned52
« Reply #2 on: April 08, 2021, 09:23:20 AM »
thank you
« Reply #3 on: April 08, 2021, 09:39:16 AM »
Take it out on the lawn where the grass or earth will soften the drop, then raise it a couple feet and as you let it drop...jerk on the shaft. Might take a couple times but it will come out, the circlip really holds sometimes.
Warlock
Magnolia, Ms
« Reply #4 on: April 08, 2021, 10:42:25 AM »
Had one like one time. Had to spray it with WD 40 or something like that and let it soak before it would come out. Had like red rust in it causing it to lock up. Wasn't my bike but another person bike. Ended up changing pinion cup and drive shaft.
David
Daniel Meyer
The State of confusion.
« Reply #5 on: April 08, 2021, 02:45:49 PM »
A modification of this...hold it up by the shaft over something soft (pile of rags, lawn,etc) and tap the side of the pinion cup with a hammer a few times.
CUAgain,
Daniel Meyer
« Reply #6 on: April 08, 2021, 07:27:50 PM »
I hope you can see this video.
https://www.facebook.com/groups/855896357793960/permalink/856098151107114/
