May 09, 2026, 01:49:41 AM *
Author Topic: mechanic in Riverside/Corona Area  (Read 8249 times)
blackvalkyrie
California
« on: April 12, 2021, 01:24:00 PM »
Anyone know of a good mechanic? I need to fix a noise grinding in my left rear ..thanks cooldude
Earl43P
Farmington, PA
« Reply #1 on: April 13, 2021, 04:47:08 AM »
Do you remove your own rear wheel for tire changes?
If so, you have enough skill to consider this:
http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
Or,  just replace the existing bearing, which is what I did. Might do the Mod when mine fails or next tire change (just put a new tire on, bearings felt fine). I've seen the axle spacers on Ebay for ridiculous $, but entire rear axles WITH the nut and spacer for the same or less $.
Collar, Rear Axle, 42313-422-000 is used on multiple model Hondas.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499337.m570.l1313&_nkw=42313-422-000&_sacat=0
Good luck if you do need a mechanic. Can't help you "there".
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
blackvalkyrie
California
« Reply #2 on: April 13, 2021, 04:09:38 PM »
I don't replace my own tire but this may be the time to learn.. thanks for the info..ride safe cooldude cooldude
« Reply #3 on: April 13, 2021, 06:21:21 PM »
It sounds like wheel bearing. If you follow the instructions in Shoptalk about reinstalling the wheel, I’m sure if you brought the wheel to most mechanics they could replace the bearings pretty cheaply. Just follow the correct procedures when you put the unit back together.
6shutr
« Reply #4 on: April 27, 2021, 06:49:37 PM »
I know this is late in responding, but I've been using Veldey Power Sorts Inc. in Indio, Ca. 44917 Golf Center Pkwy suite 10. The owner's name is Bruce, and he knows the Valkyrie. I-10 East to Golf Center Parkway exit, turn right second driveway on the right. 760 238 8589 veldypowers.com. Tell him I sent you...rick
BigMac (SoCal)
Moreno Valley, California
« Reply #5 on: April 28, 2021, 08:11:09 AM »
I took care of his bike last week. He came over and did the work while I gave him all my advice.  2funny
It worked out well and he's on the road again. Now he knows how to take off and reinstall wheel the proper way.
Dave
« Last Edit: April 28, 2021, 08:13:25 AM by BigMac (SoCal) » Logged
« Reply #6 on: April 28, 2021, 10:21:36 AM »
Dave
Guitarmoto
« Reply #7 on: June 11, 2021, 03:45:10 PM »
I'm in the same boat as needing a mechanic to remove my wheels. I need new tires and no tire shop will touch my bike as far as removing the wheels to install because it's more than 10 years old. Any suggestions? My friend has a bike jack, but I haven't done a removal and don't want to mess anything up. Is it difficult?
blackvalkyrie
California
« Reply #8 on: June 12, 2021, 03:54:03 PM »
well it's not super easy..kinda need someone who knows how to do it..like
Dave did for me
« Reply #9 on: June 12, 2021, 05:06:32 PM »
Dave did for me
He should be well on his way to the Ohio Inzane by now.
