June 16, 2025, 10:52:08 AM *
Inzane 25
Author Topic: This never happened before  (Read 2193 times)
crow
Toujours Pret
Citrus Co Fla
« on: April 23, 2021, 05:35:05 PM »
running 80ish mph. Engine  cuts off, only for a split  second.  Then runs normal.  Does it again  five minutes  later.  Keeps doing this, but only at 3 to 4k rpms.  Not  a fuel issue,  definitely  electrical.   I'm sure  its hard on the rear drive.  It's like flicking the kill switch..  Haven't  checked  anything  yet.  Coil going bad?  Bad plug wire? Anyone  experienced  this?
that your ass cant cash
« Reply #1 on: April 23, 2021, 06:05:18 PM »
I believe that very symptom has been discussed on here before.
I don't know how to search for it.  (you'd get wider response from the 1500 tech board)
« Last Edit: April 24, 2021, 03:55:08 AM by Jess from VA » Logged
agrady1995
« Reply #2 on: April 24, 2021, 03:50:41 AM »
Happened to me out in green swamp off of 471... Kept dying random. Had to pull the bike apart at 12 midnight.
There was a single wire that was loose on a plug connector, accessible from the right side of the bike, and it went into the main wiring harness headed in the direction of the steering column. I forget what the bike was and I'll try to take a pic of the wire before lunch and get it uploaded here somehow. Ended up soldering it into the connector and it works fine now. Would go out randomly and if I hit a bump. Occasionally it would go out if I hit the kill switch (found it when I tried to turn the bike back on).
Hope this helps, I'll send a pic of the wire up here soon...
crow
Toujours Pret
Citrus Co Fla
« Reply #3 on: April 24, 2021, 05:06:07 PM »
Thanks for the replies. Hasn't  been bump related. Ughh,  would rather be beat  with a stringer of salt  water catfish than chase a bad wire.  Btw, I know  that section of road (471)  pretty  damn remote. Have traveled  it many  times, turning north on 33 to Groveland and stopping  at Krispy's Chicken.  Yum yum, great gizzards!
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: April 24, 2021, 05:46:23 PM »
Mine did that a long time ago. It stopped doing that after I took apart the kill switch, cleaned it with electronic cleaner spray and reassembled. No way of knowing if this may be the same thing.
JimC
SE Wisconsin
« Reply #5 on: April 24, 2021, 06:18:42 PM »
One of my valks did that several times one summer. It always fired back up by itself in a second or two. Pretty unnerving, but I never did anything about it.
Jim
Jim Callaghan    SE Wisconsin
agrady1995
« Reply #6 on: April 26, 2021, 09:32:10 AM »
Whoops.. Fell asleep.
https://ibb.co/R0v0TJT
The wire is red, where it isn't covered in shrink wrap. This is on the right side of the bike.
Thunderbolt
Worthington Springs FL.
« Reply #7 on: April 28, 2021, 03:46:50 AM »
Seems like I remember that scenario at some point.  Don't remember exactly what it was but definitely electrical.  Kill switch, kickstand switch, loose wire in harness under right side cover.
