January 30, 2026, 06:31:57 AM *
Author Topic: not valk related UPDATE  (Read 3171 times)
sugerbear
wentzville mo
« on: January 04, 2010, 06:23:07 PM »
i have an 05 chevy k1500. recently something has started draining my battery overnight.
tried a new battery. not it. checked the charging system battery was 12.7, started voltage was 14.3
truck starts fine all day then drains overnight.
am i right to charge the battery up, put an ammeter on it and start pulling fuses until i find the offending circuit?
just waiting for weather to warm up enough that the brass monkey can go out with me Roll Eyes
turned off all the "frills"  headlight delay, courtesy lights, horn honk on lock/unlock, etc
truck started just fine this morning.
i'll turn each one back on and see which one is the culprit.
thanks for the input and i'll update later
« Last Edit: January 09, 2010, 05:35:27 PM by sugerbear » Logged
mikehallbackhoe
« Reply #1 on: January 04, 2010, 06:43:58 PM »
you are right,  sounds like something is draining the battery. have you recently added something to the truck?
« Reply #2 on: January 04, 2010, 08:42:44 PM »
Pull the tail/brake light fuse 1st.
If that is your drain, take the tail lights out and polish all the contacts and run a new/good ground wire........
The way i check them is pull the positive cable and run a glow light between the battery post and the cable.    As the drain slacks up, the glow light will go down. or out    There will always be some draw, clock, radio memory an etc.
Post back and let us know what it was after ya find it and fix it.
Warlock
Magnolia, Ms
« Reply #3 on: January 04, 2010, 08:49:35 PM »
Also check your ground wires good. Make sure they are grounded good on the engine block and also the frame.
David
junior
new hampshire
« Reply #4 on: January 05, 2010, 01:24:23 AM »
if its a chevy, the alt should have 1 wire that feeds the batt, remove it  from the alt  using a test light remove the neg term and put the testlight in between the neg cable and neg post touch the alt cable to the stud of the alt it the testlight lights up you have a bad diode in the alt. whitch is backfeeding and drainning your batt
« Reply #5 on: January 05, 2010, 04:15:45 AM »
Yep, what you want to do is correct.. This is one place where you can still use a test light and look for voltage.. Has something happened or been done recently, like a jump start ??
sugerbear
wentzville mo
« Reply #6 on: January 05, 2010, 06:53:42 AM »
yes, the truck set for about 4 months. battery went dead then. jumped it and drove it for several months.
nothing has been added or removed.
thanks i'll start with these suggestions and let you know.
PatrickDoss
Alabama
« Reply #7 on: January 05, 2010, 08:01:44 PM »
Be aware that when you first reconnect the battery through the meter, the draw will be a lot higher than after it's had a chance to sit for, say, 30 minutes.  There are a lot of modules that need to power up and then time out.
« Reply #8 on: January 06, 2010, 04:53:37 PM »
Sounds like a draw but check the battery also, I have seen batteries that will hold a charge in for awhile and then drop dead. Sometimes its a sulfated cell especially if you let the battery drop dead while it was sitting. You need a regular battery tester to make sure. But you are on the right track
« Reply #9 on: January 07, 2010, 07:38:14 AM »
Yep, I also agree with Robert that it could be the battery if no current draw is found.. Batteries today can be a real problem when they have gone flat and have been recharged.. Another thought is, do you have any electronic corrosion protection ?? They are famous for failing and will then draw a battery in  matter of hours..
sugerbear
wentzville mo
« Reply #10 on: January 09, 2010, 05:36:17 PM »
bump
junior
new hampshire
« Reply #11 on: January 10, 2010, 12:00:33 PM »
so a bump fixed it?
« Reply #12 on: January 10, 2010, 12:24:38 PM »
so a bump fixed it?
Maybe he dropped the battery.  Undecided
« Reply #13 on: January 10, 2010, 02:48:56 PM »
Bump heh,, Sometimes bumps are great things.. They re-align all the electrons and get them flowing in the right direction,, they can be stubborn like that sometimes.. I know I need a bump every now and again,, JoAnn bumps me with a pot to get me flowing in the right direction at times..
sugerbear
wentzville mo
« Reply #14 on: January 10, 2010, 07:10:59 PM »
just updated on my first post, reread it.
ya my wife "bumps" me too, she makes sure the bruises don't show though. Cry Cry
« Reply #15 on: January 11, 2010, 07:25:43 AM »
If I were a betting man, I think my money would be on the courtesy lites..
