August 17, 2025, 01:06:47 AM *
Author Topic: Two Brothers Headers installed. Bike runs too lean - Help!  (Read 1737 times)
thevalkdude
« on: May 23, 2021, 09:37:57 PM »
Installed the 6 in to 6 pipes on my 97 Stock bike. I know the bike is for sure running lean. Plugs are white as when they were new!
My Air Bleeds Screws are about to fall out - 4 plus turns out!!
Anyone have guidance on which jets to use for this set up? I have a 97 Stock Black on Black. No other mods.
Thanks a bunch.
Leathel
New Zealand
« Reply #1 on: May 23, 2021, 11:22:13 PM »
you could try lifting the needles by putting a shim under the needles..... can do it with carbs in easily
« Reply #2 on: May 24, 2021, 03:54:44 AM »
If you are running a K&N air filter those lean out the mixture. Going back to OEM could help
« Reply #3 on: May 25, 2021, 07:43:34 AM »
Thanks a bunch.
with today's gas, plugs will usually be white. so almost impossible to read plugs today, the old pics of plugs running on leaded gas do not apply.  u are not running lean.
« Reply #4 on: May 26, 2021, 06:55:58 AM »
Thanks a bunch.
I haven't heard or seen that, about not being able to read plugs due to gas (or anything, actually).  But one thing is certain - and that's CHANGE.  (Little stays the same.)  The useless EPA creates lots of problems, including forcing vehicle makers to set them up to run lean.  Even if you do no mods.  Especially at low altitude.  He is for sure running lean even before dropping backpressure with his 6-6 "drag" pipes, if the bike hasn't been rejetted.  Typical is 17-1 even with OEM pipes.  Optimal is more like 14-1.  He is likely even thinner than 17-1.  A good dyno guy could confirm it but I think plugs can be read.
Of course he would be much better off if he can get pure gas.  Murphy's chain sells midgrade pure.  Don't know their distribution however.  I always buy that even though midgrade is unneeded for most of my vehicles.  Though my blown bobber requires premium so I have to use the ethanol crap.  Find pure gas stations in your area with this link - https://www.pure-gas.org/
« Last Edit: May 26, 2021, 06:59:10 AM by MarkT » Logged
« Reply #5 on: May 26, 2021, 07:15:37 AM »
https://jetsrus.com/FAQs/FAQ_spark_plugs.htm
I've had my bike on a FactoryPro dyno with four gas analyzer.  Plugs were almost white even running pig rich at WOT at 10:1 ratio.
midrange to idle my ratio was spot on, plugs showed very little color.
RustyValkry
New Jersey
« Reply #6 on: May 26, 2021, 08:00:36 AM »
I'm not commenting because I know the subject, rather because of what I found when I started working on the RustyValkyrie.
The PO had a set of TBR 6 into 6 pipes for the bike.  They weren't mounted but they came with it.  There was a set of stock pipes on it.  When I went through the junk in the saddlebags I found the kit pictured below.  When I tore down the carbs I confirmed the Cobra needles and springs were installed.  The jets were stock.  Since I had the stock pipes on I thought I might put the carbs back to stock but I discovered one of the needles was missing so I just left the kit installed.  Dynojet kits are pretty common in the Harley world, I was surprised to see one with my bike.
Someone's suggestion to shim the stock needles might help but like I said, I'm not knowledgeable about carbs.  I successfully rebuilt mine but that's easy compared to tuning them..
CoreyP
Bluffton, SC
« Reply #7 on: May 27, 2021, 07:19:03 PM »
That about what I got with my bike and no way to know exactly how the bike was setup. It runs well so I don't fool with it. Bike came with truck stack glass pack exhausted install.
RustyValkry
New Jersey
« Reply #8 on: May 28, 2021, 07:58:48 AM »
I wanted to get the dynojet kit out so I could start with a stock carb setup.  My bike seems to run rich so it might well be the dynojet kit that's causing it.  I seem to recall it would cost something like $26 for one stock needles, so I decided against it.
BTW, for the OP, the Dynojet kits are still available . . . and pricy in case you wanted to consider that route.  As I said before I'm not knowledgeable about tuning carbs and can't endorse that route but it's possible.
« Last Edit: May 28, 2021, 08:04:41 AM by RustyValkry » Logged
« Reply #9 on: May 28, 2021, 08:02:46 AM »
lower the needles by moving the clip up one notch to lean it out.
