January 30, 2026, 06:32:23 AM *
Author Topic: Rattlebars Kickshift  (Read 2256 times)
dreamaker
Harrison Township, Michigan
« on: January 06, 2010, 03:17:00 AM »
Is anybody using Cobra Boulevard Floorboards with the Rattlebars Kickshift and the Relo kit. If so any clearance issues.
Dan
Foozle
Lexington, KY, USA
« Reply #1 on: January 06, 2010, 03:35:10 AM »
The only issue I've had with this setup (and it's minor) is with the sidestand access clearance on the driver's side floorboard - which I had to bend outward slightly so as not to scrape the board edge when the sidestand is down.  The kickshifter itself works wonderfully in this configuration; just adjust your stock shift peg up or down accordingly.  Terry
dreamaker
« Reply #2 on: January 06, 2010, 05:46:29 AM »
I have now I guess you would call it the standard Cobra Floorboards which are shorter then the Boulevards.  I didn't know if there would be a clearance problem with the Boulevards. I know about the kickstand, I just put a rubber knob on it.
Thank You
Dan
Foozle
Lexington, KY, USA
« Reply #3 on: January 06, 2010, 09:38:07 AM »
Sorry, you're probably right.  I didn't know Cobra offered more than one size of floor board.  Terry
fstsix
« Reply #4 on: January 06, 2010, 10:54:47 AM »
Here is a pic of the Rattlebars kick and the Cobra's, with the Peg lowering kit also. if ya got big feet you will have to move the shifter down one notch. it is missing the chrome bolt cover you will see by looking close at this pic, dont know when that happened?, must have been having to much fun. ???
