January 30, 2026, 06:32:19 AM *
Author Topic: Tank feul filler panel  (Read 2350 times)
Mike M in ohio
« on: January 06, 2010, 03:23:32 AM »
Now, as a newbie, I'm sure I'll get countless guffaws, asking such a simple question, but here goes: I purchased a studded Mustang tank bib (along with MUCHO chrome accessories) for my "new" Interstate. It obviously sets under the gas filler chrome panel, but for the life of me, I don't see how this is loosened to lift it up and away from the tank. I only see the two phillips head bolts holding the hinged gas cap in place. Does the tank need to be removed to gat at connectors underneath?
    I'm sure the answer is obvious and I'm just missing it.
    Also, while here displaying ignorance....a follow up: I purchased the Cobra six/six pipes for my red and black beauty. Does Honda sell an appropriate jet kit, or, should I contact Cobra for a specifically designed set? Any other tips or items I'll be needing for install?
    Thanks for all the advice, in advance. This rig is making this insanely cold Winter a bit more bearable, as I work with her and dream of two wheeled tours awaiting me in the near future. Happy 2010 to all.           Mike in N.Y.
shortleg
maryland
« Reply #1 on: January 06, 2010, 04:07:23 AM »
  If you open the gas filler with your key, you will see
two small screws.  Take these out [Be careful not to drop them]
  This will is all that holds it on.
             Shortleg[Dave]
« Reply #2 on: January 06, 2010, 09:02:23 AM »
If you leave the baffles in the Cobras you likely won't need to rejet.
Warlock
Magnolia, Ms
« Reply #3 on: January 06, 2010, 09:57:16 AM »
When you remove the stock pipes be sure and remove the old exhaust gaskets. It will look like there are not in there but they are. Install some new exhaust gaskets and be careful when tightening the nuts up. It only torques to 7 ft lbs and they will ring off real easy. Also after installing the Cobra pipes you will need to go back and check the torque on the a couple times after riding it for a week or so. Like Willow said if you leave the baffles in no need to re-jet. You will loose a little power and re-jetting will put you back pretty close to stock hp, but you will loose gas mileage.  These has some good power so a little lost in hp is no big deal.
David
Thunderbolt
Worthington Springs FL.
« Reply #4 on: January 06, 2010, 03:20:27 PM »
Take out old gaskets, they will be flat little suckers.  A small screwdriver or ice pick like device if you are old enough to remember ice picks will get them out.  Wink  Like Warlock said, be very careful when you tighten the nuts, the threaded part of the stud is easy to break off.  Just snug them up good going from stud to stud a couple of times.  The first few times you ride it, snug them up again, after a few times like this, you will have flattened the donuts enough they won't get too loose too soon.
Mike M in ohio
« Reply #5 on: January 06, 2010, 07:54:17 PM »
Thanks again to all for the assistance. This is one great club, peopled with a variety of caring riders. Glad I finally discovered my Valk and this fine organization.    Mike
