August 17, 2025, 01:08:39 AM *
Author Topic: Memphis Shades Windshield Replacement Help/Question  (Read 1191 times)
Frankj
« on: May 31, 2021, 12:59:23 PM »
Hi, I've had the widshield for many years and just bought a replacement windshield, did not need the hardware. When I removed the metal brackets is that double sided automotive tape that's behind them to hold the brackets close to the windshield, along with the bolts?
I carefully pulled the brackets away from the old windshield and there is some type of adhesion that was used
Frank
« Reply #1 on: May 31, 2021, 02:19:41 PM »
If I remember correctly it is just a rubber gasket. Probably got sticky with heat and age.
Frankj
« Reply #2 on: May 31, 2021, 06:50:56 PM »
The more I look at it I think you are right
Thanks for your response
Frank
