November 12, 2025, 10:15:56 AM *
Pages: 1 [2]   Go Down
Author Topic: Rotor Replacement and Lifting the Bike  (Read 2856 times)
Malkozaine
Lake County, Illinois
« Reply #40 on: June 06, 2021, 08:42:28 AM »
Nope...only need to lift the rear tire 2-3 inches off the floor to pull the wheel. I used my centerstand to do that but a bike lift will do the same for you.
  • I then slip a floor jack under the swingarm and pull the shocks loose. Then you can lift the swingarm up/down at will.
Will do.  Another question, are Rotors different on a regular Valk, Tour, and Interstate?  I look around and find ones that say for regular Valk and Tour but very few say Interstate.
Agreed. I wasn't meaning to lift the bike 2-ft in the air. Just state the general idea for Malkozaine's level.
I use a scissors lift under the swingarm. Use to use a ratchet strap.
Anyways, removing the rear wheel has enough of it's own quirks.
Malkozaine, I suggest you start a new thread on lifting the rear wheel ..... with or without using a regular lift jack.
Will do.  Another question, Is there a difference between Reg, Tour, and Interstate Valk rotors for the front and rear?  When looking them up most talk about the Reg and Tour Valk but I rarely see them mention the Interstate.
« Last Edit: June 06, 2021, 08:57:32 AM by Malkozaine » Logged
RonW
Newport Beach
« Reply #41 on: June 06, 2021, 09:11:38 AM »
the front are same I  think. The rear rotors have a few nuances.
2000 Valkyrie Tourer
« Reply #42 on: June 06, 2021, 10:36:25 AM »
All Valkyrie front rotors are the same all are interchangeable regardless of std, tourer, IS
« Reply #43 on: June 08, 2021, 10:13:23 AM »
Here's a previous thread on my permanent, installed lift adapters.  Lightweight, installs in 5 minutes w/o removing anything, prevents damage to your exhaust from the jack, install and forget it until you need to lift the bike.  Handy on a road trip especially.  I donated 4 of them to be given away at the Inzane drawings next week.  I have these in stock, ready to mail.  http://www.valkyrieforum.com/bbs/index.php/topic,105040.0.html
Pages: 1 [2]   Go Up
