November 12, 2025, 10:13:51 AM
Tire help
Topic: Tire help (Read 1248 times)
shadowmagic
Tire help
June 08, 2021, 07:53:51 AM »
So, I plan on replacing my tires very soon starting with the front one since I'll be tearing down the front end to replace forks and bearings. I will also be painting my calipers white along with some misc. pieces at the front of the bike. I was wondering if anyone knows where I can get tires that are whitewall or have the white lettering going around the tire? All I've been able to locate is regular solid black tires. Any help greatly appreciated.
h13man
Indiana NW Central Flatlands
Re: Tire help
June 09, 2021, 06:31:12 AM »
Metzler's 888's @ $500 a set.
Promagnaman
North Dakota
Re: Tire help
June 14, 2021, 06:32:07 AM »
What is a good place to order tires from?
h13man
Re: Tire help
June 14, 2021, 07:10:56 AM »
Rocky Mountain or American Motorcycle Tires are my usual suppliers.
https://www.rockymountainatvmc.com/
http://www.americanmototire.com/catalog/
DeathWishBikerDude
Re: Tire help
June 14, 2021, 07:32:03 AM »
https://www.ebay.com/itm/392772966822?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=392772966822&targetid=1263433206694&device=m&mktype=pla&googleloc=9033663&poi=&campaignid=10459842381&mkgroupid=122657840056&rlsatarget=pla-1263433206694&abcId=2146002&merchantid=6536044&gclid=CjwKCAjw_JuGBhBkEiwA1xmbRdvmY9chMcgB9fXW4gBaqI6yQ5fTWwEE7tp-lZaldMAcBT3WeyoxpRoCcWoQAvD_BwE
And a dark side...$200..lmfao
Quote from: h13man on June 14, 2021, 07:10:56 AM
o
DeathWishBikerDude
Re: Tire help
June 14, 2021, 07:35:07 AM »
I run the Kendra on the front with reverse rotation currently.
I'm planning on running the next front tire with the correct rotation.
I get a slight vibration currently at 120 mph.
Dark side tire is getting replaced because it's 5 years old..plenty of tread left..just being safe..
Ken aka Oil Burner
Mendon, MA
Re: Tire help
Reply #6 on:
June 14, 2021, 07:48:43 AM »
If the OP wants white walls, dark siding is out. While there may be exceptions out there somewhere, most white wall car tires are only WW on one side. Blackwall on the other side, giving the car owner the choice.
Finding white walls in standard Valk sizes may not be too easy either. May have to run some "close" sizes, depending on what you can find.
https://www.amsoil.com/?zo=5889580
Ken aka Oil Burner
Mendon, MA
Re: Tire help
Reply #7 on:
June 14, 2021, 07:53:53 AM »
For white lettering, you can buy tire paint pens to DIY them yourself. Then you can buy any blackwall tire you want and customize it. You can find them on Amazon, and probably at some parts chain stores too.
Also, some people have used these Sharpie paint pens to do tire lettering:
https://smile.amazon.com/dp/B00WL2STGM/?coliid=I1X977J3ZZ8MA&colid=229LI4BKBACV&psc=1&ref_=lv_ov_lig_dp_it
Last Edit: June 14, 2021, 08:05:28 AM by Oil Burner
=> InZane XXV
