August 21, 2025, 08:54:07 AM *
Author Topic: Sure is great riding in cool comfort.  (Read 903 times)
« on: June 22, 2021, 09:10:26 PM »
Last night I stopped early in the Chattagnooga area, I was hot, hot, hot and tired. Fortunately, although not planned my early stop saved me from riding in a horrible storm. This morning, it was beautiful so I got out and after a quick b'fast at a nearby awful Waffle House, I hit the road for Vandalia, IL. Weather was great, in the 70's most of the day so made the best of it and covered the full 456 miles only stopping to eat a couple times and a couple stops to simply stretch the legs. Not bad for an old fart! Grin After riding that far I'm surprised that I'm not tired, the heat simply saps your strength...and my patience.
One thing I've noticed re. the trike, it apparently has a lower gear ratio than the stock drive. At 3k rpm I'm only showing about 64mph...somewhat less than OEM and the front tire is stock size so should be a fairly accurate comparison. So far mileage is in the low 30's which is acceptable considering the size of the trike and the load I am carrying along with the speed I was running. My AudioVox cruise is working great and holds speed quite close...when not in the mountains or hill country I run right at 70 with no issues. Surprisingly, the semis still blow by me. Cheesy
Avanti
Stoughton, Wisconsin
« Reply #1 on: June 22, 2021, 09:35:37 PM »
You need to feel like your outrunning the police to keep the semis at bay.
henry 008
BRP
willard, oh
« Reply #2 on: June 23, 2021, 07:13:40 AM »
Safe Winds... Brother
TJ
Lake Placid , Fl.
« Reply #3 on: June 23, 2021, 07:31:06 AM »
« Reply #4 on: June 23, 2021, 08:43:14 AM »
    Glad ya hit dat Cooler air!  coolsmiley Heat and The THING that makes the heat Worse-Humidity!  Lips Sealed I personally Do NOT see Any 600  700 mile days on Phatt Ghurl in my future no mo.  Undecided  John My Friend-Just Be Safe out there!  cooldude You KNOW the lament Every one of us as Riders have heard-Sorry Dude didn't see ya!  uglystupid2 As others have asked-keep us updated please! RIDE SAFE.
« Reply #5 on: June 23, 2021, 02:48:01 PM »
One thing I've noticed re. the trike, it apparently has a lower gear ratio than the stock drive. At 3k rpm I'm only showing about 64mph...somewhat less than OEM and the front tire is stock size so should be a fairly accurate comparison. ...
Indicated speed is tied to the front tire.  RPM distributes through the rear tire(s).  Compare rear tire size to the OEM Valk tire size.
JimC
SE Wisconsin
« Reply #6 on: June 23, 2021, 04:06:00 PM »
Rear tire size AND rear end ratio.
John has a trike with a modified car rear end, so I doubt he knows what the ratio is without checking.
Jim
Jim Callaghan    SE Wisconsin
« Reply #7 on: June 23, 2021, 04:21:57 PM »
An excellent point.
« Reply #8 on: June 23, 2021, 05:08:45 PM »
Regardless of axle ratio, given the 3000 rpm target and difference in speed between the bike and the trike it seems a slightly larger rear tire could possibly move the speed up closer to what John was used to seeing. Might not be practical due to handling and clearance issues.
« Reply #9 on: June 23, 2021, 06:31:56 PM »
Those are some fat tires in back, just don't recall the size but have looked at it. I'll probably leave it as it is, I just found it interesting that the speed was down in relation to rpm. What I really need to do when I get home is carry my GPS a couple times to do an actual speed check compared to indicated. Let you all know the results.
