October 08, 2025, 07:17:33 PM *
Author Topic: Front brake caliper: do all valkyries use the same part?  (Read 2035 times)
Savago
Brentwood - CA
« on: June 28, 2021, 01:19:52 PM »
Gentlemen
Some of you may remember the troubles I had with a motorcycle shop that botched my I/S final drive (i.e. no lub, no new o-rings in two tire changes crapped the FD leaving me stuck in a roadtrip in Sequoia NP).
Well... when I bought the I/S years ago before the whole FD mess, I had them replace the front brakes pads.
Back then, in my ignorance, I thought that such important safety item had to be done by 'professionals'.
Well turns out that yesterday when I went to replace the brake pads, just had another 'nice' surprise left by the shop so-called mechanics:
a) The right side caliper mounting bolts were basically loose (only hand tighten).
 Shocked
b) The pin-hanger (that long bolt that keeps the pads in place and is screwed in the caliper body) is stuck, probably overtorqued.
 Angry
After trying to break it loose and failing, I left it soaking in penetrating oil overnight (Kano Aerokroil) and brought the bike to a new shop near home.
I didn't want to strip the pin-hanger head or running the risk of breaking it (already had a really bad experience breaking the mounting bolts of the alternator, but that is another story).
The mechanic tried to break it loose (even using heat) but said it is stuck and suggested me to try to source a new front right caliper.
I asked if he knew of a good machinist that could know of a way to handle the stuck bolt (i.e. like soldering) and he said that the 2 last ones he knew are either retired or closed their shops thanks to environmental regulatory laws in Kommiefornia.
The current issue is that the part 45250-MZ0-006 is no longer available (https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/front-brake-caliper).
I'm trying to buy an used one from evilbay right now.
It seems that all Valkryies (standard, touring, interstate) used the same part number according to partzilla:
a) Standard: https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500c-a-valkyrie/front-brake-caliper
b) Touring: https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500ct-a-valkyrie-tourer/front-brake-caliper
c) I/S: https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/front-brake-caliper
The first question: Do all valkyries use the same right front caliper (45250-MZ0-006
Finally, assuming that I manage to find an used one, it seems like a good idea to rebuild the caliper since the whole thing will be apart.
I recall that redeye (https://redeye.ecrater.com/) had carburator rebuild kits, do they offer a kit for caliper rebuild? If not, anyone knows of a supplier with a good kit to buy?
Finally, since I'm doing an overhaul in the front brake, I'm considering the idea of buying new brake rotors.
At least the rotors seem to be still available (https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/front-wheel) but I recall once a post mentioning that the rotors of the 1800cc goldwing were compatible. Anyone could confirm this?
They seem to be a bit more expensive i.e. near $360 each vs $240 for the I/S (https://www.partzilla.com/catalog/honda/motorcycle/2002/gl1800-a-gold-wing/front-wheel) but may be easier to source.
« Last Edit: June 28, 2021, 01:41:14 PM by Savago » Logged
« Reply #1 on: June 28, 2021, 01:42:12 PM »
I believe all front calipers are the same.  Many good ones available online.
I would rebuild both the new right and old left so that they will work in tandem equally, hopefully.  I get the parts from Partzilla.  New rubber and maybe new cylinders.
I apply Never-seize generously to the pin and black cap and the black cap is only just snugged.
I never replaced a rotor, but I would mic them first before doing so.
« Reply #2 on: June 28, 2021, 02:30:13 PM »
The 1800 wing rotors are compatible(‘01-‘10). They are 3.5mm vs 4.00 to start but I had them on my previous Valk with no problems.
As for getting the set screw out, try a hand impact screwdriver. They are handy to own when working around steel and aluminum.
« Reply #3 on: June 28, 2021, 06:36:55 PM »
Gentlemen
 Shocked
 Angry
https://www.jkozloski.com/generic_parts.htm
Madmike
Campbell River BC, Canada
« Reply #4 on: June 28, 2021, 06:45:23 PM »
https://pinwallcycle.com/advanced_search_result.php?keywords=gl1500+C+front+brake+caliper
« Reply #5 on: June 28, 2021, 07:29:45 PM »
on ebay right now, there is a guy parting with free shipping, a whole set or rotors for less then $100, I was even thinking of buying them. The rear was miced out as almost new thickness. He had other parts. I thought the prices where reasonable, and I thought they where from CA.
Savago
Brentwood - CA
« Reply #6 on: June 28, 2021, 08:05:13 PM »
Damn... you guys are awesome*.
All good advice, keep it coming.
I bought a pair of calipers from pinwall, should have them at home in a couple days.
I assume that to rebuild them, the following parts would be needed (from partzilla: https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/front-brake-caliper):
a) Seal set (06431-MA3-405): https://www.partzilla.com/product/honda/06431-MA3-405?ref=6e224817f68c52d12ef37d2de58aeffa95994e8b
b) New pistons (it seems to be 2 different parts 45107-ML4-006
 and 45107-MZ0-760): https://www.partzilla.com/product/honda/45107-ML4-006?ref=6e224817f68c52d12ef37d2de58aeffa95994e8b and https://www.partzilla.com/product/honda/45107-MZ0-760?ref=6e224817f68c52d12ef37d2de58aeffa95994e8b
Anything else (aside the new pads and pin hanger that I already bought)?
* just won a bet with my wife, as I said even with political differences, this club wouldn't let a fellow valkyrie rider be hanging with no help.
Savago
Brentwood - CA
« Reply #7 on: June 28, 2021, 08:06:30 PM »
Gordon: got a link (maybe through PM)? I searched ebay and couldn't find it, only found a vendor with new rotors but for a Touring model which I think wouldn't fit an I/S.
Avanti
Stoughton, Wisconsin
« Reply #8 on: June 28, 2021, 09:15:11 PM »
https://www.ebay.com/itm/324693277307?hash=item4b993a3a7b:g:dW4AAOSwKdVg2Jjs
Savago
Brentwood - CA
« Reply #9 on: June 28, 2021, 10:45:34 PM »
Outstanding!
Just ordered.
« Reply #10 on: June 29, 2021, 03:52:18 AM »
I've rebuilt probably a dozen calipers over the 2plus decades of my life with a Valkyrie.
I've only replaced cylinders on 2.
If their not pitted, a good cleaning should do it. Same with the pin.
I inspect the rubber pieces and most times I replace them, but not always.
Cleaning the races the seals fit in is important. New seals every time.
« Last Edit: June 29, 2021, 03:54:33 AM by Hook#3287 » Logged
« Reply #11 on: June 29, 2021, 04:50:39 AM »
only use similar to this for pins and other brake parts.  anti-seize can dry and/or wash out.
https://www.permatex.com/products/lubricants/specialty-lubricants-brakes/permatex-ultra-disc-brake-caliper-lube-5/
Savago
Brentwood - CA
« Reply #12 on: June 30, 2021, 11:07:38 AM »
Really good info, I will wait for the calipers to arrive and inspect the cylinders before deciding to order new ones.
« Reply #13 on: June 30, 2021, 06:14:12 PM »
I should have stated I only use the never-seize on the pin and cover threads.
Savago
Brentwood - CA
« Reply #14 on: July 05, 2021, 10:20:27 AM »
Update: received the seals (original Honda parts) and the used brake rotors.
They seem in good shape and I measured 4.97mm in one and 4.94mm in the other, which is way better than the ones on my I/S (4.34mm).
Still waiting for the calipers to arrive (they are in CA already, so may be delivered in a couple days).
As I have further updates, I will post here.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #15 on: July 05, 2021, 10:22:40 AM »
Service limit for front rotors is 4.0mm
DeathWishBikerDude
« Reply #16 on: July 06, 2021, 03:10:30 AM »
The valk is so easy to work on.
Never been to a shop yet.
Tire shop yesterday refused to mount a tire for me.
Went down the road to a used car dealership who quickly mounted the tire in 5 minutes.
I avoid mechanics as much as possible.
« Reply #17 on: July 06, 2021, 06:26:02 AM »
Don't get the impact screwdriver from Harbor Freight - this one:
https://www.harborfreight.com/6-bit-impact-screwdriver-set-with-case-64812.html
The bits are so brittle they broke immediately for me.  Vessel makes JIS screwdrivers that also have an impact function - the ones with a metal cap. Not sure they can impart as much torque as a proper heavy-duty impact screwdriver.  I would buy the latter from a quality toolmaker - that is, NOT CHINESE.
Might try this one - good ratings:
https://www.amazon.com/Vessel-NO-250001-Impact-Driver-No-250001/dp/B001WHOV64/ref=sr_1_1?dchild=1&keywords=Vessel+Impact+Driver+No.250001&qid=1625578413&sr=8-1
« Last Edit: July 06, 2021, 06:35:18 AM by MarkT » Logged
