November 12, 2025, 08:30:16 AM
Actual function of IGNITION COIL and connections
Topic: Actual function of IGNITION COIL and connections (Read 1161 times)
agrady1995
June 30, 2021, 09:41:19 AM »
Hello. I realize the ignition coils use a waste/dual spark system. I also realize that it's just a HV transformer timed to pulse on when called to fire.
Does anyone have the pinout/wiring pins and the input voltage/type (DC, 12V input right?) for the transformers?
I'm looking to use one of these in a side project (coils) and am hoping to wire one up to use for the purpose of making spark for the duration of a momentary push button.
Thanks in advance!
Kilroy
Mooskee
Southport NC
Re: Actual function of IGNITION COIL and connections
June 30, 2021, 05:00:10 PM »
I emailed you a set of diagrams.
Valkyrie Carbs and Custom
www.valkyriecarbsandcustom.com
Jims99
Ormond Beach Fl.
July 01, 2021, 04:32:44 AM »
You’re also going to need a way to fluctuate the power to coil on and off. The coil will only spark once when the power is turned on and off. If you’re not running it off a battery, use an ac transformer, not dc. That will give you a constant on/off.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Mooskee
Southport NC
July 01, 2021, 02:40:42 PM »
A high voltage AC transformer, like a fluorescent sign transformer will work. With the output sent to a small gap, and the transformer energized, it will continually arc. Like the "Jacob's ladder" you see in the old sci-fi flicks. They just hook two diverging rods to the output. When it arcs, it climbs the V due to heat, until it cant jump the gap any more. Then it starts over. An old sign transformer will put out something like 15000 VAC.
Timbo1
Tulsa, Ok.
July 01, 2021, 08:12:01 PM »
For $4 plus the cost of a momentary switch and a couple nuts & bolts you could take the electronics out and connect the leads to the bolts as a spark gap. When momentary switch is depressed it sparks.
https://www.harborfreight.com/electronic-fly-insect-swatter-62540.html
=> InZane XXV
