February 12, 2026, 09:18:47 PM *
Author Topic: High idle/desmog  (Read 1578 times)
RonA
Saskatchewan
« on: July 03, 2021, 05:32:17 PM »
I believe I have a vacuum leak, the bike idles fine in cool weather but increases as the air temperature increases, up to 2500 rpm at 35C. It also surges at idle once warmed up. I am tempted to cap off #1-5 vacuum ports, plug the smog lines, and replace the #6 line to the fuel petcock to solve the leak and minimize future leaks. Is this an acceptable repair or do you have to remove/alter more of the smog equipment?
« Last Edit: July 10, 2021, 04:56:56 PM by RonA » Logged
« Reply #1 on: July 03, 2021, 06:47:26 PM »
There are other places where a leak will cause this. Intake runner clamps, exhaust gaskets and O rings under the chrome intake runners can leak. Check all of this for a cure.
RonA
Saskatchewan
« Reply #2 on: July 03, 2021, 07:20:35 PM »
Have snugged up the intake clamps and runner and exhaust bolts, no change. This started after I removed the tank to replace the air filter. I suspect the fuel petcock vacuum line, I had to remove it to remove the tank. Looks good from the outside but is hard to inspect. Thought that I might just eliminate all possible leaks now and in the future by capping off all but #6.
« Last Edit: July 03, 2021, 07:28:42 PM by RonA » Logged
Madmike
Campbell River BC, Canada
« Reply #3 on: July 03, 2021, 09:29:05 PM »
Little bit of starting fluid may help find it
RonA
Saskatchewan
« Reply #4 on: July 04, 2021, 07:12:29 AM »
Yeah I have a propane tank with a line for "sniffing" it out, still curious if I can just block off the smog and cap those ports.
RonW
Newport Beach
« Reply #5 on: July 04, 2021, 07:49:15 AM »
To answer your question people have to reach back and remember the purpose for all the tubes when they did their desmog. Might take a while.
2000 Valkyrie Tourer
« Reply #6 on: July 04, 2021, 10:00:02 AM »
What you are describing is called Stealth Desmog. Search for it, and see if anything else is missing in your proposed desmog, I can't remember.
Since you had your tank off, are you sure you got all the intake rubber correctly on the carbs? I would suspect a folded over edge somewhere. An endoscope or a mirror should help out here.
RonA
Saskatchewan
« Reply #7 on: July 04, 2021, 10:10:56 AM »
Thanks, will search stealth desmog. I just removed the tank and refreshed the K+N filter. I did not remove the air box, just the lid.
RonA
Saskatchewan
« Reply #8 on: July 10, 2021, 05:36:35 PM »
I have eliminated a vacuum leak as the cause, using a propane bottle and hose. I removed #1-5 vacuum hoses/plugs and installed new caps. The #6 line was replaced to the petcock. There was no change. The idle is smooth but low, 500rpm at 15C, smooth at 20C 900 rpm, 1500 rpm at 25C, a bit bumpy at 30C 2000 rpm.
It does this consistently.
I can adjust the idle down to 1000 rpm at 30C, but then it barely idles in cool weather. The throttle cable has the proper free play, the choke/enricher cable also. All of the enrichers move freely, out and in. I checked the carb sync, it was within spec but I touched it up a bit to get it right on. The bike has always pulled strong, maybe a bit smoother at +3000 rpm after the carb sync. All 6 plugs look identical, a light gray color. I replaced the engine coolant temperature sensor, part #36151-MT8-003, no change.
When I purchased the bike last summer it idled perfectly. Since I bought it I have changed the engine and final drive oil, flushed the rad, brake lines, clutch line, set the valves, and refreshed the K+N air filter. It is a great bike to ride, but I am at a loss to figure out this gremlin. My gut tells me it is something simple but I just can't figure it out.
« Last Edit: July 10, 2021, 06:31:51 PM by RonA » Logged
Jims99
Ormond Beach Fl.
« Reply #9 on: July 11, 2021, 06:57:51 AM »
Maybe try some fuel additives to clean out anything small. If it sat at all, could have slightly clogged up something. I’ll throw some b-12 in on occasion just to make sure they’re ready when I am.  It does sound like something simple.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #10 on: July 11, 2021, 11:37:39 AM »
B-12 is great, and inexpensive, but only available in the USA. I've used my last bottle, and buy a couple each year for the spring start up and a long ride. ($4USD?)
Techron would be the next I would try, unknown qty/gas for troubled bikes. But I would just do your best to buy fuel at Chevron.
My first thought, how long do you idle for? Forget about it and ride. Unless you stall at a stop, just turn the idle up a little.
RonA
Saskatchewan
« Reply #11 on: July 12, 2021, 08:50:02 AM »
I did run a stiff tank full of Gumout fuel cleaner through it. Supposedly with the P.E.A. additives it's one of the better ones available in Canada. It made no difference. When I parked it last fall it was idling great. I topped off the tank, treated the fuel, and drained the carbs. This spring she fired right up. I am not sure when or why this issue started, it showed up when the weather turned hot.
 Your right it's no big deal, just frustrating.  I have been using it as is, it is a great riding bike. Run the idle at a compromise, 400 rpm 10C, 1500 rpm 30C.
