February 12, 2026, 07:31:09 PM *
Author Topic: Horn chatter?  (Read 1151 times)
strawbobrob
It's all in the wrist.
« on: July 07, 2021, 08:54:21 PM »
I have the four horn setup on my interstate and over time three failed and I was sounding like a pipsqueak so I bought replacements and installed.  Now the horn sounds like an audio machine gun—ak-ak-ak-ak-ak! But nice and loud again with all four blowing.  Did I cross a wire or something? Am I shorting the system?  Did I buy cheap horns? What is the meaning of life?  Thanks in advance wise men of the Valkyrie!
« Reply #1 on: July 08, 2021, 05:50:09 AM »
I have BigBF quad horns, I guess that's what you have?
Once, on a trip, one of the un-loomed wires I had added
to my accessory fuse box shorted out. When I figured it
out and cobbled together a fix...
... the horns blew continuously. I'd wired them up blindly following
BigBF's instructions. When Gordon demanded to know "why the
&^%$!! did you do it like this? ! ?" I didn't have a good answer  Wink ...
Anywho... later, at home, I stripped out the BigBf wiring that
I didn't understand and wired them up like I thought they
ought to go... all four grounds to ground and a relay makes
all four hots hot... they work great now...
Jersey
VRCC #37540
Southern Maryland
« Reply #2 on: July 09, 2021, 06:59:33 AM »
Highly recommend (if not already) using a high power relay that is activated by the horn switch.  Also, VERY important to use a relay that has a Flyback Diode installed.  Otherwise you'll have major voltage spikes produced that can mess up other parts of the electrical.
Jersey
