February 12, 2026, 07:32:22 PM *
Author Topic: Fuel shutoff rebuild  (Read 1369 times)
da prez
Wilmot Wi
« on: July 11, 2021, 07:36:33 AM »
  I have done several but think I made a mistake. (do not work when not feeling up to par).
 I serviced a Valk that I had put off for quite a while. I think I put the shutoff together wrong.
 Bike runs and shuts off like a vacuum problem. Open fuel cap , no real difference. A couple minutes it will start and run again.  In my mind I I did something wrong with the petcock. It will idle for 15 minutes but shuts down at highway speed.  Asking for a picture of assembly of petcock. I thought I had one.
 It is the only thing I touched in the fuel system.
                                                da prez
Mooskee
Southport NC
« Reply #1 on: July 11, 2021, 08:05:20 AM »
Here is a video. There are others as well on YouTube.com
https://www.youtube.com/watch?v=RHTt_dhJskc
Also there is a pic in this shoptalk article: http://www.valkyrieriders.com/shoptalk/petcock.htm
I'm sure you will figure it out. Good luck.
« Reply #2 on: July 11, 2021, 08:26:05 AM »
You can also go manual, but an electric fuel shutoff is highly recommended if you do.  Better than the OEM vacuum setup IMHO.
Easy method here:
http://www.rmworksinc.com/files/a-Belly_tank_instruction_manuel-pdf.pdf
(see page 5)
« Reply #3 on: July 11, 2021, 09:22:18 AM »
There's a fellow who posts some good assembly order pictures
into posts like this, hopefully he'll chime in...
This picture I found in my stash would help to get some of the
parts in the right order and orientation...
I like this shop talk article...
RonW
Newport Beach
« Reply #4 on: July 11, 2021, 11:29:07 AM »
https://youtu.be/RHTt_dhJskc?t=137
2000 Valkyrie Tourer
« Reply #5 on: July 11, 2021, 11:51:31 AM »
From Grython Rider
http://www.valkyrieforum.com/bbs/index.php/topic,37577.0.html
da prez
Wilmot Wi
« Reply #6 on: July 13, 2021, 07:51:53 PM »
It was my screw up. I didn't have it properly seated. I drove to his home and redid the mistook.  crazy2
  I have done many , but it was my mistake.
           da prez
