February 12, 2026, 07:32:40 PM
99 I/S trunk latch ?
Topic: 99 I/S trunk latch ? (Read 1259 times)
Whooray
Idaho State Rep
Kuna, Idaho
July 14, 2021, 02:20:19 PM »
Is there some way to adjust the trunk latch? Right now it closes just can't get it to latch
Appreciate your advice. Raymond
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
JimC
SE Wisconsin
Re: 99 I/S trunk latch ?
July 14, 2021, 03:48:45 PM »
I have had several interstate trunks and each one of them is the same.
If you slam it down, they will pop back up without latching. What I learned to do is close it, then put heavy downward pressure on the lid and they will catch.
I have heard that there is an adjustment on there somewhere, but never needed to do it after closing it like above.
Jim
Jim Callaghan SE Wisconsin
Jims99
Ormond Beach Fl.
July 14, 2021, 07:05:58 PM »
I agree with Jim. I adjusted mine to close easily, but that caused it to rattle terribly. Try pushing down to latch. If it won’t, there is adjustment on the lid side if need be.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
SCain
Rio Rancho, NM
July 16, 2021, 05:43:45 AM »
The lid lock bar can be adjusted, just a little, loosen the two screws and slide it one forward or back to see what works best.
Closing my trunk, I press on the "K" to secure the latch.
Steve
Steve
Rio Wil
July 16, 2021, 05:25:24 PM »
A little lube on the latches works wonders....
Whooray
Idaho State Rep
Kuna, Idaho
July 21, 2021, 09:28:08 AM »
UPDATE........ adjustment made works great without any rattle,
I appreciate all your input.
