February 12, 2026, 07:32:15 PM
Stupid Question
Topic: Stupid Question (Read 1420 times)
Fazer
Stupid Question
July 16, 2021, 08:59:02 AM »
I should probably know this, but when I remove the temp sensor at the bottom of the radiator, am I going to lose the coolant?
Nothing in moderation...
Ken aka Oil Burner
Mendon, MA
Re: Stupid Question
July 16, 2021, 12:21:55 PM »
I'm going to go with yes; you will lose some coolant. If you do it quickly, you may not lose as much as you think. As long as you don't remove the radiator cap, there will be no way for air to immediately replace the lost coolant from the topside; sort of like a vacuum seal. Break that seal and the coolant can flow more quickly out. I've done this sort of thing on cars a time or two. If you're replacing the sender, have the new sender ready to go. Loosen the old one. Antifreeze will likely weep past the threads once it's loose. When it comes out, put your thumb over the hole. Grab the new one. Move your thumb and install the sensor as quick as you can. You should lose the least amount by this method.
Of course, if you're due for a cooling system service, now's probably as good a time as any.
https://www.amsoil.com/?zo=5889580
Ken aka Oil Burner
Mendon, MA
Re: Stupid Question
July 16, 2021, 12:24:09 PM »
If you try this while the engine is warm, the coolant may be under pressure. I'd recommend my method when it's completely cold; like after an overnight sit.
Re: Stupid Question
July 16, 2021, 01:01:16 PM »
Air can get in through the rad cap. Pinch the vent line with a clamp or small vise grips.
Ken aka Oil Burner
Mendon, MA
Re: Stupid Question
July 16, 2021, 06:53:28 PM »
Good point. Not nearly as quickly as if the cap was off, but the cap does in fact allow some bypass. If it didn't, the cooling system wouldn't be able to draw coolant back from the overflow bottle as it cools down. As Sandy said, a small clamp or a pair of vice grips pinching off the overflow hose to the tank would just about eliminate the ability for air or coolant to enter the topside of the system.
Bret SD
San Diego, Ca.
Re: Stupid Question
July 17, 2021, 08:26:06 AM »
I replaced mine a couple years ago, not much coolant loss happened if memory serves.
Bret
02 Standard -- Blue & White
82 Aspencade -- Red
rws
1997 Valkyrie Tourer
North Dakota
Re: Stupid Question
Reply #6 on:
July 19, 2021, 08:20:31 PM »
Quote from: sandy on July 16, 2021, 01:01:16 PM
how is air gonna get in...it's a closed system...the only way air can get in through a properly functioning cap is if the vent line has a leak or the overflow tank is empty
https://www.freeasestudyguides.com/engine-radiator-cap.html
Last Edit: July 19, 2021, 08:22:38 PM by rws
Original VRCC Member Number 697
1997 Honda Valkyrie Tourer - 2019 Honda CRF450L - 2021 Honda Rebel 1100 DCT
