February 12, 2026, 07:32:20 PM *
Author Topic: Bog down when throttle  (Read 1538 times)
teadream42
« on: July 16, 2021, 02:02:49 PM »
Hello everyone. I have a new and interesting problem. Recently my baby will not start . Took it to my local mechanic and he diagnosed that the ignition pick up/pulses coils was bad . He replaced the coil, it’s start up and I took home . Have not ridden for a month ,put in new gas , but now it bogged down when I throttle  up. Needing some help and guidance.its feel like fuel issue.  I tested the petcock and it was okay.
Took the spark plugs out and the right side (all 3) is darker,more carbon bill up then the left side.
« Reply #1 on: July 16, 2021, 03:11:04 PM »
Valkyrie’s don’t like sitting for a month. Put a strong dose of chemtool B12 that should improve things
GWS
Central New York
« Reply #2 on: July 18, 2021, 06:44:55 AM »
I've read posts from a few guys on this forum about using a strong dose of Chemtool B12. I've used the recommended rate of 1 oz. per gallon with good results. Just wondering what constitutes a "strong dose"? 2x the recommended rate?
Also, Berryman makes a B60 product for fuel systems that have been sitting/neglected for a long time. (FWIW, their definition of neglect is a fuel system that hasn't been cleaned or treated in over 3,000 miles.)
Has anyone tried the B60 product on a Valk that's been sitting for months or years?
« Reply #3 on: July 18, 2021, 11:21:38 AM »
If I remember right. A bottle treats 15 gallons and I put half a bottle in a full tank. That’s my definition of a strong dose.
RonW
Newport Beach
« Reply #4 on: July 18, 2021, 12:40:40 PM »
I avoid using a strong dose of B-12, etc. My theory is strong doses may loosen big clumps and clog up things. After several rinse cycles a strong dose won't hurt. Abeit by then a strong dose won't be necessarily.
My recommendation for storage is Marine Stabil.
2000 Valkyrie Tourer
« Reply #5 on: July 18, 2021, 01:46:07 PM »
When I bought the Bruce bike. BF tried but he couldn’t  keep up with keeping her running. It sat for a long time and barely ran when I got it home. It only had a quarter of tank of gas so I filled it and added half a bottle of B12. Took two days to ride out that tank. Filled and added the other half. By the time I rode the second tank out it was running perfectly. Just my story
rug_burn
Brea, CA
« Reply #6 on: July 20, 2021, 12:26:18 PM »
Makes me wonder what's in some of those additives.
   I think B12 has a bunch of light aromatic solvents, kind of like toluene and the like, but the others, Techron, Lucas' product, Gumout and others have very little smell; some even advertise that they use jet fuel for the main component or carrier, which is a lot like Diesel fuel...
  I'd like to hear what a chemist would have to say.
...insert hip saying here..
RonW
Newport Beach
« Reply #7 on: July 20, 2021, 04:25:31 PM »
Bottom line is B-12 does a better job than other fuel treatments, smell test or taste tests not withstanding. Costs half as much as Seafoam which was the only thing I used until Seafoam doubled their price, stupids. I haven't tried Techron. But B-12 is cheaper.
DeathWishBikerDude
« Reply #8 on: July 25, 2021, 09:25:31 PM »
Best fuel treatment is acetone..dont use much and run most of the tank dry..if your going to let the bike sit again.
